Finding and Identifying Crawlspace Mold
person with a mask in a crawlspace
  • 1 hours
  • 25
Particle mask
Flashlight
chlorine solution
Particle mask
Flashlight
chlorine solution
Crawlspace mold is a fungus type that grows naturally on plants. It is most often associated with humid crawlspaces and in places such as bathrooms, basements, and attics.
Mold spores travel through the air. When the right conditions for breeding occur, they grow fast and may become a problem. Initially, mold indicates greater humidity levels that should be addressed as soon as possible. In this way, you will stop fungus from spreading around your home.
Spotting the Crawl Space Mold
Identify and inspect the mold in crawl spaces. If moisture is excessive and ventilation is poor, mold has the right conditions to grow and flourish. If the air is stuffy or a bad smell is discovered, mold growth has already started.
Ventilate the space for as long as possible. Look for mold in the corners and in any moist area. Check all niches and corners with a flashlight if space is poorly lit or has no windows.
damp and dark crawlspace
You should always wear breathing protection or a particle mask when you suspect and look for mold. If you find mold in moist areas, it is important to note the color of the mold in order to select the appropriate method to treat it. Be careful not to spread the mold and be especially careful not to inhale it.
It can cause various allergic reactions or respiratory problems. If the mold has already spread at full speed, professional help may be required. An expert will determine the type of mold and help you avoid this problem in the future.
If you find mold in your basement or house, ask your neighbors whether they've had a similar problem before. The fungi may be typical for the area and the problem may be common. It may help you determine the fungus type without seeking professional help.
How to Avoid the Appearance of Crawl Space Mold
The best prevention is the regular airing of your home or basement. If that is not an option, you should think of other ways to go about it. One approach is to frequently treat the crawlspace with anti-fungus chlorine solutions or to use a humidity controller or dryer which keeps the air dry.
Moist conditions are a good friend of mold; they should be kept within reasonable limits. Put a barometer in the crawlspace in order to monitor the humidity level. If it starts to increase, take precautions immediately. Before long, the mold will begin to spread. Air out space or turn on the dryer to minimize humidity in the crawlspace.
Precautions While Treating the Crawl Space Mold
Remember that anti-mold solutions are typically poisonous. Do not inhale fungus spores and do not touch them if your hands are not protected. Use glasses and gloves while treating them. In addition, use some cloth to cover your mouth and nose or a particle mask in order to prevent inhaling, swallowing, or even absorbing the mold through your skin.
