How to Repair Bathroom Tile in 5 Steps
If you have a few broken or stained tiles on your bathroom floor, bathroom tile repair costs less than a complete renovation. Follow these simple steps to complete this weekend project.
Step 1 - Remove Grout
Using a utility knife, remove all grout around the damaged tile. If it’s a soft grout, just pull at the grout with the knife until it all peels. If it’s a hard grout, you will need grout remover. Follow the packaging instructions. These products can take up to an hour to work. When using grout remover, be careful not to spill it on the ground around other tiles.
Step 2 - Remove Old Tile
Depending on how the tile was attached to the floor, removing it can be very easy or very hard. If the tile is just lying in place, then all you have to do is pull it out. Most of the time, floor tiles have been set in using an adhesive. If it’s been many years since your last flooring job, the adhesive may be hard to remove.
If the tile is held fast, you can loosen it using a nail punch. Punch a hole in the broken tile and start to chisel at the tile and the adhesive. You can use the hammer and chisel on the outside edge of the tile, working inward to avoid damaging other tiles. You may cause some damage to the sub-floor while doing this, but the new tile will conceal it nicely.
Step 3 - Prepare for New Tile
Ensure that there is no debris left from the old tiles, especially if you had to break them. Vacuum dust and leftover grout and adhesive, even if you don't see any. Doing so will reduce adhesion issues later.
Place the tile on the bare spot before you glue it in. Make sure it doesn’t rock and that it’s even with the other tiles. If it stands higher, you will need to remove more of the adhesive underneath. If it rocks, remove debris until it sits evenly.
Step 4 - Place New Tile
Prepare the new tile by applying a thin layer of adhesive on the back using your putty knife. Don’t bring the adhesive any closer than a .5-inches from the edge. Set the tile in place by wiggling it back and forth. Ensure that the tile securely placed exactly where you want. Give it at least 24 hours to bond.
Step 5 - Grout
Apply grout with a putty knife only after the adhesive has completely bonded. Use a damp sponge to wipe excess around the other tiles.
