Fixing a Dryer Belt That Squeaks
2-4 hours
Beginner
- 35-50
You can tell when a dryer belt needs to be fixed or replaced from the squeaky sound it makes when you run your dryer. The belt will squeak when the drum rollers or the idler pulley are defective. Once the dryer belt is fixed, the parts causing the belt to be under stress can be repaired. It is a repair that can be completed on your own without hiring a professional. There are just a couple of things you will need to complete this job. The steps are listed below.
Step 1 - Shut Off the Power Supply
Shut down the dryer’s power supply by unplugging the electrical cord from wall outlet.
Step 2 - Remove Control Panel
Unscrew the 2 screws that attach the top of the dryer and control panel. Place the control panel in a spot that is far from the area in which you will be working. Do not remove the wires.
Step 3 - Remove Top Panel
Take off the dryer’s top panel. Do this by removing the retaining clips which hold it down. Remove the 3 screws located at the panel’s back, and slide it off.
Step 4 – Remove the Front Panel
Remove the screws connecting the sides and the front. Swing out the front panel’s top. Now, lift front panel up from the retaining tabs on the dryer’s bottom.
Step 5 - Check the Belt
Examine the belt for any damage or wear in it. If the belt is stretched, it will cause a squeaking noise while the dryer runs. It should appear tight and firm without visible wear or damage. It will need to be replaced if it’s broken, damaged, or loose.
Step 6 - Release the Tension on the Belt
Locate the idler arm at the bottom of the drum’s side, near the motor. Push it back, in order to relieve some of the belt’s tension. Remove the belt from the motor drive and idler arm pulley.
Step 7 - Remove the Drum
Take the belt in one hand. With your other hand, take the drum and lift it up. With belt in your hand, slide the drum away from the dryer.
Step 8 - Inspect the Pulley
Spin the idler pulley with your finger to test it. If it does not spin freely like it should, it needs to be replaced. If that is the case, unhook it from the dryer’s base and replace it with a new one.
Step 9 - Inspect the Drum Rollers
Check the drum rollers at the rear, on which the drum rests. If they do not spin freely, they will also need to be replaced. It is best to replace both of them at the same time.
Step 10 - Replace the Drum
Remove the triangular clips that hold the roller. You need a screwdriver and a socket wrench to do so. Place the belt around the drum. Put the drum back in its place in the dryer. The squeaking noise should now be fixed.
