Flat Paint Basics Explained
Flat paint can be used for many purposes. From it's uses as a primer to dozens of surface types or applied to drywall as a finish coat. It's versatility, ease of use, and, it's adhesion performance to so many types of surfaces is one of the reasons that flat paint has had so much success among paint professionals and homeowners alike.
Another reason for it's sustainability in the market is because of it's highly competitive price. When compared to most other types of paint available, others can't compete with this low cost product that can be applied to varieties of surfaces.
Application of Flat Paint to Metal
Flat paint is used largely by paint professionals as a primer for many types of metals creating a bond-able surface for rust preventative enamels, latex enamel and alkyd enamel to adhere to. This is only a hand full of products that flat paint teams with to create a long lasting finish.
Application of Flat Paint to Wood
It is used as a primer for almost any variety of wood and woodwork used as a primer to seal wood grain for a smooth surface. By this, it invariably does the dirty work for enamel finish products to actually be the reason for the woods beautiful, flawless finish. Flat paint is also partially responsible for the longevity of a lot of paint jobs.
Application of Flat Paint to Drywall
Flat paint is used as a primer for drywall surfaces as well as a finish product. It is used as a primer to textured drywall prior to applying latex paint products. Also using flat paint to size walls prior to the application of wallpaper gives the wallpaper maximum adhesion to the drywall. Sizing is a term best described as primer. The process of preparing drywall surfaces for best adhesion of wallpaper glue. The importance of sizing prior to wallpapering shows its best example in areas such as a bathrooms where moisture is high and where wallpaper glue fails most often.
Flat paint is also used often by many professionals as a finish coat to textured drywall surfaces such as ceilings primarily, but also to walls on the commercial and residential level. The lack of sheen from this product is what attracts a lot of customers to flat paint. This can be a good attribute to have, but it also can be the reason for its failure in one area of performance.
Cleaning Surfaces Painted with Flat Paint
Cleaning a surface with flat paint as its finish coat can be a nightmare. In fact, it is not recommended due to its inability to withstand scrubbing to remove dirty spots. What happens when attempting to scrub a wall painted with flat paint is that with every scrub, layers of paint comes off too. Either you will end up with a bare spot or a shiny spot if all the paint has not been completely removed. The reason it begins to shine is because when applying water and scrubbing, the clay base of the paint breaks away from the acrylic components, thereby leaving the part of flat paint that has shine to it. The reason flat paint has the sandy flat appearance is due to the clay base that it is made of. Scrubbing removes the clay, so it loses its flat properties.
Although it has very few areas where it lacks to measure up, flat paint is the backbone to most all other paint products in today's market. When choosing flat paint as your paint solution, you can rest assured it is the place where all good paint is born. Performing at its peak, flat paint can handle the workload for thousands of jobs.
