Flemish Bond Brick Pattern Explained
Flemish bond brick pattern is the most common and classic of brick laying patterns. It can be found on many modern and historical buildings. It is also one of the most difficult brick patterns to lay properly because every brick must be lined up perfectly horizontally and vertically.
What Kind of Wall Is Flemish Bond Brick Pattern Best Suited For?
Flemish bond brick pattern is best suited for a wall that is 1/2 a brick thick. It is also best suited for support walls. Generally, this decorative design is used on the exterior of homes or on the interior of lofts to create an industrial look.
How Do You Lay a Flemish Bond Brick Pattern?
A flemish bond brick pattern is created by laying down alternating headers and stretchers on each layer of brick. While all the bricks must align perfectly horizontally, each header and stretcher must align perfectly vertically. This means on every other layer of brick, the end of each header must be in line with the one below and each stretcher must be in line with the one below it. The placement of the headers and stretchers will be identical on every other layer of brick.
