4 Mobile Home Roof Repair Tips
Repair on a mobile home roof.
A mobile home roof can suffer damage from many causes. One of the most common causes is excessive weather conditions. The type of roof and the amount of damage that any mobile home experiences will determine how much repair work can be carried out personally. Here are some tips on repairing your mobile home roof.
1. Go to the Professionals
Bring in contractors for estimates of work. Doing so will give you a framework for the amount of work that needs to be done, what process should be followed, and how long the repairs will last.
2. Can You Repair It Yourself?
If your mobile home roof is composed of asphalt, the repairs will need to done by a professional. The professional may be a caretaker located on a mobile home park. It could also be an independent contractor. If there is a lot of damage, you might need to consider some form of mobile home financing.
3. Be Specific
If the roof is made from acrylic elastomeric covering, it will require two coats of roof coating. There are also different types of roof coating that vary in price, so always make sure the correct type is used for your individual needs.
4. Fill in Holes
For bigger leaks, use glass fiber or melted plastic to repair the holes, then apply silicone sealant. When the holes have been covered, apply a layer of roof paint for additional protection.
