Garage Door Openers
Double garage in an angle view
If you are in the market for a garage door opener, there are definitely a lot of options for you to consider. Most garage door openers last for a long time, and you generally do not have to replace them very often. This means that when you are ready to buy a new one, the features may have changed substantially. This garage door opener buying guide is designed to take some of the confusion out of buying a new garage door opener. With this information, you should be able to look at the different features that are available and find a garage door opener that works best for you.
Chain drive -- The chain drive is the most commonly used type of garage door opener. As the name implies, with this type of opener, a chain is responsible for lifting the door. The chain goes through the motor and back out the other side to provide a lifting motion. This is the least expensive type of garage door drive that is available, but it is also the loudest.
Screw drive -- The screw drive is another type of garage door opener that you can purchase. With this type of garage door opener, a metal bar is threaded through the drive and pulls the door up. This type of garage door opener is known for being slow, but it is a little bit quieter than chain drives.
Belt drive -- The belt drive is the type of drive that you will find on most high end garage door openers. With this type of garage door, they use rubber belts to lift the door. This is by far the most quiet type of garage door opener that is available. This is also the most expensive, as it can cost as much as two times more than a chain drive model.
Power -- One of the features that you should look at when you are purchasing a garage door opener is the amount of power that it has. As a general rule, you should try to get the most power that you can afford with your garage door opener. The more power that it has, the better it will perform in the long run. For example, if you have a large double door, you should get a garage door opener that has at least 1/2 hp. Larger motors on doors will last longer than motors that do not have as much horsepower because it will be easier for them to lift the door.
Security Features
Something else for you to consider when purchasing a garage door opener is the safety features that it comes with. Most garage door openers on the market today come with a rolling code feature. With a rolling code, the garage door opener generate a unique pass code every time that the door is used. This prevents other garage door openers from working on your door.
If you want to be safe, you might consider looking at some other security features that come with doors today. For example, there are some garage doors that have an electronic lock feature. With this feature, the garage door will actually detect if someone is trying to force the door open. When this happens, the door opener will initiate the motor to close the door and keep it closed.
Some garage doors will also allow you to set up a temporary password. For example, you can give this password to your family and friends to make sure that only they can get in and out of the garage door.
The security light is another feature that is commonly found on garage doors. When you walk into the garage, you will pass through an electronic beam. Many garage doors trigger a light to turn on immediately in order to illuminate the garage.
In addition to being secure, you also want to make sure that no one is injured by the garage door. Because of this, most garage doors offer safety features. The electronic sensor that goes across the floor under the door will detect if anything is in the way. If something is under the area where the garage door closes, it will prevent the door from coming down. Many garage doors also have a sensor that is activated if the garage door touches something on the way down. When it is activated, the garage door will open back up quickly.
Remote Control
You should also look at the type of remote control that is provided with the garage door opener. Many models come with a single button remote that opens and closes the door. Other garage door openers come with a multi-button remote. With this type of remote, you can actually program it to open and close multiple garage doors.
Keyless Entry
Some garage doors also come with keyless entry. This allows you to set up a numeric keypad on the side of the building directly outside the garage door. Then, if you need to get into the garage door and you do not have your garage door remote, you can simply type in a secure code, and the door will be opened. This is a good way to allow your friends and family access to your home if you are not around.
Fixed Control Button
You should also make sure that your garage door opener system comes with a fixed control. This is the button that you put on the wall inside the garage. It will look like a doorbell or a standard type of button that you can push to open and close the door. Some of these buttons are more advanced and have multiple features. For example, some of these buttons will allow you to electronically lock the door or set an alternate passcode to use. If it does not come with the set, you can sometimes purchase it as an accessory.
Quiet Operation
As mentioned earlier, the belt can have a lot to do with the noise level of the garage door opener. In addition to this, garage door openers can be made more quiet when they use direct current instead of an alternating current.
