Garage Door Repair Tips
Your garage door isn't something you give much thought to until it stops working properly. You will need to become familiar with garage door repair to keep your door functioning properly.
Brackets
The brackets hold the tracks to the walls, which allow your garage door to move up and down. These brackets can become loose, and then you need to tighten the screws or bolts into the wall. If the brackets become dented, chipped, or damaged, they need to be pounded out with a hammer or rubber mallet and replaced.
Tracks
Check the tracks to make sure that they are level and properly aligned. A horizontal track should slant down toward the back of the garage. Tracks are located on each side, and they must be the same height as the garage door walls. If you find that the tracks are not aligned, loosen them and tap them back into position. When the tracks are level, screw or bolt them back into place.
Rollers
Dirt and grease can build-up on the rollers of a garage door, and hinder the garage door from going up and down smoothly. Clean the rollers and lubricate them with spray and powder.
Brackets
The brackets hold the tracks to the walls, which allow your garage door to move up and down. These brackets can become loose, and then you need to tighten the screws or bolts into the wall. If the brackets become dented, chipped or damaged, they need to be pounded out with a hammer or rubber mallet and replaced.
Tracks
Rollers
Dirt and grease can build-up on the rollers of a garage door and hinder the garage door from going up and down smoothly. Clean the rollers and lubricate them with spray and powder.
Hinges
The hinges on garage doors can be damaged very easily. Any hinges that have become loose, cracked, or off-center need to be replaced. If you see any cracks in the concrete of the foundation or walls near the hinges, they need to be filled.
Springs
To fix the tension on your garage door, pull the cable through the plate door and re-tie the end.
