Glass Shower Door Replacement in 4 Steps
One of the most effective methods for improving the look and feel of your bathroom is to do a glass shower door replacement. The process is straight-forward and requires a only a few basic tools, some caulk and the new shower doors.
4 Steps to Shower Door Success
- The first step is to remove the old doors. This is done by lifting the bottom of each door and gently sliding it out of its runners or track.
- It is then time to remove the old track. Remove any screws that hold the old track in, and then use a putty knife to break up the old caulk and slide the old track off the shower.
- Apply new caulk and allow it to cure for at least four hours around the new or re-used track for your new doors.
- The fourth and final step for glass shower door replacement is to install the new glass shower door in the track.
Congratulations, you have a new set of new shower doors.
