Granite Countertops Cost Value
When many people consider their ideal kitchen space, they think of granite countertops, cost aside. Granite countertops are strong, sturdy, and attractive in appearance. They provide your kitchen with not only a rustic and professional feel but also with a sturdy material that will be durable for many years to come. Granite countertops come in a variety of colors, shapes, designs, and other styles to best suit the needs of your kitchen space and your own desires as well. For these reasons, granite is one of the most popular materials to choose from for a kitchen countertop.
Therefore, it is not surprising that granite resurfacing is one of the most common remodeling projects that homeowners undertake to improve their kitchen spaces. However, granite countertops are also among the most expensive of the different types of kitchen surfaces that you can buy. Read on for a breakdown of the cost value of these countertop materials.
General Cost of Granite Countertops
When considering the cost of granite countertops, you must keep in mind that you'll have to factor in both the cost of the material itself as well as the cost of installing it.
Cost of Granite Material
Granite material varies in cost depending upon a number of factors. These include the thickness of the stone, the purity of the stone, the color, whether the top surface of the stone is left rough-hewn or has a shiny veneer covering over it, and more. Therefore, the cost of the granite countertop material itself generally ranges from around $50 per square foot all the way up to $150 per square foot. White granite and dark gray tend to be the most expensive colors, with sandier colors and lighter grays somewhere in the middle of the price range and black as the lowest.
This does depend upon your local market, however, and where the granite comes from. There are also many other factors that can influence the cost of granite and which may be worth paying a bit of extra money for. For instance, certain types of granite are stronger and more resistant to scratches, stains, and cuts. These cost more money but might be a good investment if you're interested in preserving the look of your granite for many years to come.
Cost of Installation
The cost of installing your granite countertop depends upon the manner in which you do it. If you complete the installation at home without the help of a professional contractor, you can expect to pay a few hundred dollars for the cost of the materials and for your time spent working. A contractor will likely be able to finish the job faster, but his hourly rate may be such that you end up spending more money. In either case, it's good to expect that you'll spend upwards of $1000 on the cost of installing the countertop itself, for a standard-size counter and kitchen space.
