Greenboard vs Fireboard: Advantages and Disadvantages
Greenboard is a type of drywall. Nowadays, interior walls as well as ceilings are constructed with panels made of gypsum plaster that is pressed between two sheets of thick paper and dried in a kiln. These panels are known as drywall. Drywall is one of the most basic materials used in building and construction. Today, there are various types of drywall available in the market. Most people opt for the standard drywall in most of their applications. It is, however, better to make an informed decision and be aware of the alternatives that are available. Both greenboard and fireboard are similar in that they are both types of drywall, they can both be cut with the help of a saw, and they can both be used in similar situations. However, they are also very different. The difference lies in their compound properties and their make-up.
Greenboard – Advantages and Disadvantages
- Greenboard is very similar to regular drywall, with the exception of the following two aspects. Greenboard is covered with a green colored paper (from which it derives its name), and this paper is water resistant. Greenboard is available in sizes that are different to regular drywall, and it is preferably used in areas such as the basement, bathrooms, etc., as these areas are generally prone to dampness and humidity. Greenboards can be used on both floors and ceilings.
- However, you should avoid using greenboard in areas that get wet as this might cause mold to grow or even lead to a total failure of your product. Greenboards are not resistant to fire, and thus, they should not be used in places like the kitchen, where chances of a fire are slightly higher.
Fireboard – Advantages and Disadvantages
- Fireboard, on the other hand, is made using materials that are non-combustible as well as glass fibers. It also has a gypsum core. It does not disintegrate like your regular drywall does due to the fibers it contains. In short, fireboards do not disintegrate as easily as drywall and make for a good barrier in the case of a fire.
- Fireboard also has properties that are resistant to moisture and can be used in rooms where the moisture content is very high such as your basement, bathrooms, etc. Moreover, fireboards also have sound resistant properties, making them a good option for sound proofing. The sound protection provided by a fireboard compares to a number of layers of your regular drywall.
- Fireboard is more expensive as compared to greenboard.
Greenboard vs. Fireboard
The benefits of using a fireboard far outweigh the use of a greenboard. Your regular drywall or greenboard, on average, may offer resistance for about 60 minutes in the case of a fire. As compared to this, fireboard helps protect your home and offers resistance for at least 2 hours. However, also remember that fireboards only help retard the heat and smoke; it is not completely fire proof. Perhaps, the best solution is to use greenboards in damp and humid areas of the house, and fireboards in areas where there is an increased risk of fire.
