Heater Safety: Convection Propane Heaters vs Electric Heaters
When you bring out your heaters in those cold winter nights to stay toasty warm, you must keep in mind some basic heater safety tips. Whatever kind of heater you own, you should always use it in a safe way to prevent any safety issues. Here are some heater safety tips that you should put into practice whether you own a convection propane heater or an electrical one.
Choose Wisely
Whether you intend to purchase a convection propane heater or an electric heater, one important factor you must consider for both types is to pick reliable models. When buying a heater, look for a good quality heater rather than going for a cheap one. Opt for recommended brands that offer safety features like automatic safety switches which turn off the unit if it is accidentally tipped over.
Propane: Keep Units Away From Flammable Items
Ideal for heating large industrial areas as well as large urban rooms, convection propane heaters are meant to operate in an open space. Therefore, these heaters must be kept at least 3 feet away from any flammable items, such as blankets, papers, clothing, and even yourself. Unfortunately, these heaters can become one of the major causes of home fires when they are not used carefully, and in certain circumstances, they can also cause an explosion.
Propane:
Use the Proper Fuel
If you have a heater that uses fuel such as propane, make sure that you are using the proper fuel for your heater and not a different fuel as a substitute. Never try to use other types of fuel, such as kerosene, in your propane heater or vice versa since it can cause permanent damage to your heater and at the same time, causing it to become very dangerous.
Propane:
Never Leave the Heater Unattended
Don’t leave the house or go to bed without turning off your convection propane heater. Propane heaters can sometimes become unpredictable, so you should always be present when the heater is switched on. Even if your heater has a timer, don’t go to bed without making sure that the heater is switched off.
Electric: Hide the Power Cord
In the case of electric heaters, make sure that the heater cord is not where someone can trip over. Run the wire of your heater along the wall skirting so it will not become a tripping hazard. However, you should not run it under a rubber carpet or rag. If the cord looks damaged, don’t use it and instead, replace it with a new one.
Electric: Never Place Your Electrical Heater Near a Water Source
Since electrical heaters are powered by electricity, you should never place it near a water source. Refrain from touching an electrical heater with wet hands. In this way, you will eliminate any risks of electric shock.
Both convection propane and electric heaters need careful handling when in use, and safety must be a top consideration. Although electric heaters are considered safer, regardless of whether you are using a propane heater or not, install and maintain at least one smoke detector on each floor of your home and test it to make sure that it works.
