How to find doorbell breaker?
I'm in the process of replacing my current doorbell. I tried to find the doorbell breaker on my panel and there's no doorbell label anywhere on the electrical panel. I found this thing on the side of the electrical panel. Do I just basically turn off each breaker and see if any of the breaker is the one for the doorbell?
Or you can just try each breaker until you hear the slight hum stop, or attach a voltmeter to the screw terminals and watch when it goes to zero.
Or if you're comfortable, remove the front panel of your breaker box and see which breaker it goes into! Lots of options!
Okay, I just thought of something. If those two red and white wires are low voltage and cause no harms to me, do I really need to disconnect or shut off the breaker to install a new Ring doorbell?
