Hot Topics: Load Bearing Closet?
Taking down a wall is really easy, and demoing a closet could take you less than half an hour. Tempting, especially if that closet is in an awkward place. But before you knock anything down, make sure it’s not there for a reason. The Forum can clue you in.
Original Post: Load bearing wall??? Can I take this down? W/ PICTURES.
mattdwagner Member
I have a closet between my living room and kitchen. Any reason that you see why I couldn't take this down? I want to take it back to the side of the kitchen counter and then build a door flush to access the water heater. Thanks.
Highlights from the Thread
chandler Forum Topic Moderator
What a funky place/design for a closet. Not being on site, we always recommend the services of a structural engineer to make determinations. With that disclaimer, it appears this closet has load bearing properties. There appears to be a beam type soffit that ends with the closet and needs vertical support.
mattdwagner Member
Thanks for the reply Chandler. When you say "beam" are you referring to the one in the last picture that protrudes from the closet from the left?
Actually I missed the stair landing. So yes, the entire square is load bearing for the landing corners. That's why the closet exists.
