Hot Topics: Screw Stuck In a Deck
DoItYourself.com brings novices and experts together in our Forums to share questions, ideas and advice. Over 250,000 members post in 120+ categories, so each week we highlight a conversation that may help with your next project. This transcript has been lightly edited.
Original Post: Suggestions for removing stripped 2" deck screws?
AshleyQuick - Member
Seven of these are stripped. Should I buy a specialty extractor or do you have any tricks?
a screw embedded in a deck
PJmax - Group Moderator
There really isn't an extractor for that application.
Usually you just wedge a small flat screwdriver under the head and lift the head up while turning.
There are several other tools like a mini wrecking bar and cat's paw that can be helpful but can damage the surrounding wood a bit.
a diagram of a cat's paw tool
AshleyQuick - Thread Starter
I have a cat's paw and they're still a pain. The 3" screws are really embedded in the joists.
XSleeper - Group Moderator
You could try these, but no guarantee they will work.
I have a pair of wire cutters (dykes) with a sharp edge that I also use to get under the head. Usually with a slight lift/wedging you can turn the screw out. You can't pull the screw directly out. It needs to be turned out.
Tumble - Member
Dremel, cut a slot for a flat blade screwdriver might work...
Good ideas, thanks guys!!
aka pedro - Member
Why are you removing them? If you're replacing boards just rip the old ones out then cut the screws off.
beelzebob - Member
If you are replacing the deck boards, chisel/cut board around stuck screw to remove deck board and then use vice-grips (gripping on threaded portion of screw) to rotate out, If not replacing deck boards, suggest cutting parallel faces on screw head (using a metal cutting disc on a dremel like tool). Grab screw head by flats ( using vise grips in a vertical position) and try to unscrew.
The board was rotten enough to yank it out, which of course exposed the remaining screws. At that point, I used vice grips to remove them.
