Hot Topics: When a New Repair Needs To Match an Old Texture
Here at DoItYourself.com we enjoy providing a place where home improvement novices and experts can come together to share ideas and advice. Inside our Forums, users can browse threads to see what exchanges are taking place on a topic of interest or start their own dialogue by posting something for the community to take part in. With over 250,000 members and counting, this resource is quite active so each week we highlight one of the conversations that may just help you with that next DIY project.
You did a good job putting up new drywall, but your repair’s going to stick out like a sore thumb because the old work has a plaster texture left over from long ago—in fact, the whole house has it, so you’re not going to get away with much of an alteration. How do you match the old with the new? The Forum fills in the gaps.
Original Post: Match Texturing
GregInGA Member
I just added a new section of drywall to an existing wall. Now I have to texture it to match the existing wall. The texture in the existing wall looks like this. The entire house has this kind of texturing so I figure it was done with a machine and not manually.
How can I match it?
Highlights from the Thread
marksr Forum Topic Moderator
Looks like it might be orange peel which is often thinned down joint compound sprayed thru a hopper gun. How thick/thin the texture is determines how prominent the texture is. How big of a section do you need to texture?
joecaption1 Member
Best bet, hire a pro sheetrock company.
Even then, they're likely going to have to retexture the whole wall to get it to match.
czizzi Forum Topic Moderator
You will want to cut back the texture at the seam between old and new enough to insert joint tape. Mud the raw side as you normally would and whatever feathers into the texture, have a wet sponge handy to blend the compound into the texture. The joint compound will fill in all the indents in the texture and want to leave you with a smooth wall. The sponge will allow you to gradually transition from texture to smooth.
Then you will need to rent a hopper gun and an air compressor. Practice on a piece of cardboard. Thin down some joint compound so that if you took a heavy marble (round) and placed it on top of the compound, it would just sink below the surface. You don't want it to drop immediately below and you don't want it to float above. Then start at the smallest opening setting on the hopper and about 20 pounds of pressure and start spattering your cardboard to see if can replicate the pattern.
Spray from 4 inches away and go back and forth until you get good saturation, gently overspraying into the old texture to blend the two together. Wait overnight for it to dry. Then take a 12-inch putty knife and scrape it along the whole wall to knock off any buggers and high spots. Prime it with a new drywall primer and paint.
If the first attempt looks like dung, scrape it while it is wet and try again. Sometimes placing a utility light close to the wall (but out of spray pattern) will help you gauge how your spray is going. Oh, and mask off everything in the room including floor, ceiling, furniture, and anything else you don't want spray on.
GregInGA Member
“Looks like it might be orange peel which is often thinned down joint compound sprayed thru a hopper gun. How thick/thin the texture is determines how prominent the texture is. How big of a section do you need to texture?”
Not very big, just about 8 feet x 4 feet.
I don't like the aerosol cans of texture but you might be able to get an acceptable job using them. Ideally, you'd mix up the texture and spray it thru a hopper gun. As Z stated, it's not rocket science and if it doesn't come out right it's no big deal to either scrape it off while wet or sand it down when dry so you can try again.
It's also possible to roll on the texture but it won't be a perfect match.
