How Does Cotton Seed Meal Affect Soil Fertility?
Soil is depleted over time by the plants that are growing on it. All plants pull Nitrogen from the soil which must be replaced. Most also require Phosphorus and Potassium in nearly equal amounts. When the soil becomes depleted, plant growth will become stunted or weak and you will have to condition it to restore the soil fertility. Bone meal is both beneficial and easy to apply, making it a very good solution for your soil.
Slow to Absorb
When cotton seed meal is added to soil, it works in much the same way a time-release capsule works in the bloodstream. All of the benefits of the meal are not absorbed right away, but are gradually taken into the soil and passed to plants. This makes cotton seed meal an excellent organic method of treating small and large plots of ground to maintain soil fertility. The slow absorption rate means that one treatment lasts for months.
High in Nitrogen
For plants, organic matter is the key to existence. As it is decomposed in the soil, plant material releases stored nitrogen which is re-absorbed by new growth. In situations, such as gardening where the nitrogen is being removed from the soil, conditioning can be used with alternating crops to keep the soil actively fertile.
Contains Phosphorus
Flowers and plants of all types require Phosphorus to live. Mixing 1 cup of bone meal into your compost every month will allow you to maintain a healthy, thriving soil additive for all of your planting needs. Bone meal is an excellent source of Phosphorus and has the added benefit of adding texture to the soil, which further encourages the growth of fungi and bacteria in the soil.
Cotton Seed Meal Contains Potassium
Bone meal is not only high in Nitrogen and Phosphorus, but in Potassium as well. Together, these three ingredients form some of the most important building blocks for life to draw on. Plants which are lacking in potassium are often weak, droopy-appearing plants, with yellowish edges on the leaves. A bone meal additive can alleviate the problem and prevent it from coming back again.
Long Term Soil Treatment
To treat your garden with bone meal, mix ¼ pound of bone meal with a wheelbarrow half-filled with sand. Using a shovel, broadcast the sand and bone meal mixture over an area that measures around 100 square feet. Till or turn the soil immediately to prevent wind erosion of your bone meal. If you are applying bone meal to a sandy terrain, mix it with compost or apply it directly. Direct application is discouraged because of the fine powdery nature of the meal which results in vital nutrients being easily lost. Repeat this process every 6 to 12 months, alternating compost and sand as the primary ingredient.
