When Should a Saltwater Pool Filter Be Washed?
  • 1-2 hours
  • 1-25
Maintaining a saltwater pool or a saltwater pool filter is not entirely different from maintaining a freshwater pool. Though there can be major differences in the pool's function, maintenance requires taking care of similar problems that may arise over time. A saltwater pool usually requires cleaning of the chlorine generator which tends to get accumulated with minerals. Unlike the chlorine generator which requires very frequent cleaning for smooth functioning, the pool filter requires maintenance every few weeks. The importance of cleaning the pool filter is still high though and knowing when to wash the pool filter can mean everything. Not washing the filter on time can result in a burned pool water pump.
Observation
Firstly, keeping an eye on the leaf basket behind the static skimmer is of high importance. The leaf basket and the hair filter that is lined directly against the water pump can get accumulated with particles very quickly over time. By basic observation, you can determine when the filter needs cleaning here.
Pressure Gauge
The most accurate and effective way to check whether your filter needs cleaning is to check the pressure gauge. If the pressure on the gauge is high, it indicates that there is excessive backpressure. This is caused by the pool filter not being lean. This should be a clear sign to know that your pool water filter needs immediate cleaning.
Make sure that when you backwash the filter, you can use the waste residue from the saltwater pool for fertilizing your garden. This depends however on whether the salt in your pool is Sodium Chloride or Magnesium Chloride, the latter being good for the garden. The former, not so much.
