How to Add Counter Space in Your Kitchen
2-15 hours
Intermediate
- 50-500
You can never have enough counter space in a kitchen, so why not create more? If you have space in your kitchen, this is a sensible thing to do because you will not only create more usable counter space, but you can use the area beneath for extra storage.
Step 1 - Finish the Wood
The piece of butcher block should need no finishing. The 24-inch length is just a general idea, it can be longer or shorter, depending on the amount of space you have in your kitchen. However, if the length is over 30 inches, you’ll need to add two more legs to support the counter top.
Sand the pieces of wood that are two inches by two inches by 33 1/2 inches in size. These will be the legs. This will make sure they’re smooth so you won’t receive any splinters if your hands brush against them. You should also put a coat of clear seal on them. This way, if you spill anything, you’ll be able to wipe it off without the wood becoming stained.
Step 2 - Braces
On the end of one leg, attach two corner braces. One brace will attach to the butcher block countertop along its length and the other along its width. This first leg will be one of the two inches by two inches, by 33 1/2 inch pieces, and will have a brace on one side with another brace on the side to its left. The second leg will have a brace on one side and another brace on the side to its right.
On the underside of the butcher block, measure in six inches from each side and make marks. Attach the remaining two corner braces here.
Step 3 - Attach the Legs
Keep the butcher block turned so the underside is facing upwards. On the end opposite the one with the corner that is already braced, measure in ½ inch from the end and draw a straight line. Next, measure one inch from the side and make a pencil mark.
Hold leg #1 against the two marks and screw the braces in place on the butcher block so the leg is very secure.
Leg #2 will be located on the corner. Hold it in place against the line and the edge then attach the screws, making sure the legs are very firm again. Now, put the plywood in place against the two legs and screw into place.
Step 4 - Attach the Top
Turn your wood so the butcher block is at the top. Slide it into place against the counter in the area where you want to have more counter space. Making sure the top of the butcher block is level with the counter top, screw the corner braces that are attached to the butcher block in place against the side of the kitchen cabinets. This will give you more valuable counter space.
