How to Build a Pool Screen Enclosure
Large glass windows with a pool outside
  • 36-48 hours
  • 1,000-8,000
Sheet metal poles
Sheet metal cutting saw
Sheet metal couplings
Screwdriver
Sheet metal drill bit
Sheet metal screws
Posthole diggers
Hammer
5-gallon bucket
Shovel
Sack of concrete
Water
Roll of screen wire
Sheet metal poles
Screwdriver
Sheet metal screws
Posthole diggers
Hammer
5-gallon bucket
Shovel
Sack of concrete
Water
Roll of screen wire
A pool screen can help protect your pool from bugs, leaves, and other debris.
You can either purchase a fully assembled pool screen enclosure or you can spend a weekend putting a new one together. Follow these steps for a successful project.
Step 1 - Purchase Screen Poles
You might be able to purchase the polls the desired height; otherwise, you will need to cut them with a metal cutting saw.
You can purchase any type of poles at your local home improvement center. They can be any style, color, or texture. Pick something that works with your outside landscaping decor.
Step 2 - Dig Holes
post hole in the dirt
Dig holes using a hole digger in the ground. If there is concrete underlayment, you will need to break through the concrete. This will be needed so you can place your poles on the ground.
Step 3 - Place and Secure Poles in the Ground
Place the poles in the holes. Make sure they are tight but not firm. Hammer them in place. They will be a little loose at this point.
Step 4 - Pour Quick Setting Concrete
cement in a post hole
Pour the concrete into the bucket and mix it according to the instructions on the bag. Pour the concrete into the hole. Make sure it comes just below the surface of the hole.
Step 5 - Smooth the Concrete and Set
Smooth the concrete with the shovel and allow the concrete in the hole dry and set for at least two to three days.
Step 6 - Roll out Wire Screen or Mesh
When the concrete has set firmly, roll the screen wire over the outer area of the poles.
Step 7 - Screw Wire Mesh in Place
mesh material
Screw into the sheet metal two sheet metal screws at the top of the pole and two at the bottom. This will secure the wire onto the pole. Make sure you leave the area open for entry into the pool and the pool ladder.
Step 8 - Test Out your Pool and Enclosure
Test out your new pool screen enclosure. You will be amazed at how well it keeps the bugs and other flying insects from intruding in on your leisurely swim and relaxing afternoon.
