How to Change Brake Pads and Rotors
5-10 hours
Intermediate
- 100-1,000
Replacing brake pads and rotors is a fairly simple procedure provided you know what you are doing. Safety should never be compromised when working on the brakes of a vehicle so you should always replace brake rotors with high quality or original equipment manufacturer (OEM) brake rotors. Cheaper alternatives, due to their inferior metal, may not dispel heat as efficiently and could squeak as a result. Replacing drum brake pads can vary depending on the model and make of a vehicle. Follow your owner’s manual.
Step 1 - Make Your Vehicle Safe
Performing any mechanical work on a vehicle can be dangerous and changing drum brake pads and rotors is no exception. Always ensure the car is parked on level ground prior to starting any work and is left in park mode. Be sure to wear protective goggles, gloves, and overalls and try to have a fire extinguisher close by in case of an emergency.
Step 2 - Identify Components and Remove the Drum Brake Pads
Before jacking up the vehicle, undo the lug nuts on the wheel. Take some time to identify the different components on the brake disc. Use the wrench and turn it counterclockwise to remove the upper and lower caliper mounting bolts. Loosen the brake pads and secondary caliper mounting bolts. Proceed to detach the brake pads ensuring that there is anti-rattle hardware to transport to the new brake pads. You can now remove the caliper mount.
Step 3 - Remove Brake Rotor
With no caliper mount obstructing the path, you can now detach and remove the brake rotor. This may require some lubrication from penetrating oil to help ease the rotor off or some gentle tapping with a hammer. To enable easy mounting of the new brake rotor, clean the bearing hub rotor mount surface. Before you can install the new brake rotor pads, you must also press in the brake caliper piston and release any excess brake fluid by taking off the master cylinder lid.
Step 4 - Install New Brake Rotor
Unpack the new rotor from its protective film and gently slide it into the same location and position you just removed the old rotor from.
Step 5 - Install the New Drum Brake Pads
Re-install the brake caliper mount and position the brake pads into place. This may be a fairly awkward process, but you must ensure the brake pads are a tight fit in the caliper mount. If the brake pads are too loose or too tight they may not work efficiently.
Step 6 - Re-mount Brake Caliper and Mounting Bolts
The final step is to put the brake caliper and caliper mounting bolts back into position. Ensure that the caliper moves without any restrictions up and down the caliper slides. Prior to driving the vehicle, always ensure to push the brake pedal to the ground and then slowly release it. Repeat the movement until you are happy that the brakes have resumed to their normal operation. By carrying out this procedure, it will force the brake pads to move to the brake rotor correctly.
