How to Choose an Interior Door Frame Kit
Lead Image for How to Choose an Interior Door Frame Kit
  • 1 hours
  • 1-20
Tape measure
Pen
Pencil
Tape measure
Pen
Pencil
If you are looking for a suitable interior door frame kit for your home, then there are a number of things that you could consider when you are looking at different frames. The size and shape of a kit are both very important to fit into the place, but you should also consider other aspects, such as ease of use and style.
Step 1 - Measure Your Space
Before you can start choosing your interior door frame kit, you will need to know whether or not it fits correctly in the space which you have planned for it. Measure your door opening carefully using a tape measure and jot down all of the details which you obtain. You will need to look for an interior door frame kit that can fit easily into the door hole.
Step 2 - Look for Ease
You will also need to find something which suits your skill level. If you are just a beginner in home improvement, then you should look for an interior door frame kit that is very basic, just a little bit of carpentry and some nailing. On the other hand, if you are experienced at home improvement, then you should consider something more sophisticated and complicated which will challenge you.
