How to Clean Toilet Bowl Stains
toilet
  • 2-3 hours
  • 15-25
Toilet brush
Rubber gloves
Pumice stone
Plunger
Stainless steel cleaner
Sponge
Washcloth
Bucket
Water
Muriatic acid
If unsightly toilet bowl stains have been a prevalent problem in your bathroom, you may be wondering how to clean them easily. It just takes a little bit of time and a few household tools.
Step 1 - Prep Your Toilet
Prepare your toilet by giving it a vigorous cleaning. Begin by applying the appropriate amount of commercial toilet cleaner to the bowl. Next, don a protective pair of rubber gloves and proceed to thoroughly clean your toilet bowl with the aid of a washcloth, sponge, or toilet brush. When performing this step, make a point of being as thorough as possible. You want the unstained areas of your toilet to be spotless before moving on to the next step.
Step 2 - Cleaning Rust Stains
Begin the rust stain removal process by shutting off the water supply to your toilet. You'll now need to pump any remaining toilet water down the drain with the aid of a plunger. After putting on your rubber gloves, squirt some muriatic acid over the stained areas and allow it to sit for several minutes. Once the acid has been given ample time to set, proceed to scrape the stains away with a hard-bristled toilet brush. Should the stains prove stubborn, repeat this process until they have been successfully purged.
Step 3 - Cleaning Calcium Stains
The first method of calcium stain removal requires the use of a pumice stone, preferably a pumice stone equipped with a plastic handle. Vigorously rub your pumice stone over the stains until they have been removed. If the stains have had a lot of time to set in, they may prove stubborn. With the right amount of strength and patience, you should eventually be able to expel them from your toilet bowl.
If you don't have access to a pumice stone, you can get rid of calcium stains with the help of a commercial stainless steel cleaner. Begin this process by mixing stainless steel cleaner and water in bucket until a pasty substance has been formed. After donning your rubber gloves, shutting off your toilet's water supply, and plunging away any remaining water, use a sponge or washcloth to spread the newly formed cleaning solution over any stained areas, then allow the solution to sit for about fifteen minutes before using a clean sponge or washcloth to wipe away the stains. Should the stains prove unyielding, you may need to repeat the process.
If you've ever wondered how to clean toilet bowl stains, just remember these helpful steps and your toilet will be stain-free in no time.
