How to Clean Your Faux Wood Flooring
  • 1-3 hours
  • 25-300
Sweeper
Vacuum cleaner
Vinegar
Warm water
Mop
Acetone
Sweeper
Vacuum cleaner
Vinegar
Warm water
Mop
Acetone
Faux wood flooring, also known as laminate flooring, is a popular choice among many homeowners. It is durable, resistant to scratches and stains and costs a fraction of the price of real hardwood flooring. With proper care and maintenance, you can keep your faux wood flooring looking as attractive and sparkling as the day you installed it.
Step 1 – Prevent Scratches and Stains
Though faux wood flooring is resistant to wear and tear, it is not indestructible. By avoiding damage in the first place, you can do a much quicker job of cleaning up the floor. Place rugs near all entry points in your home and avoid wearing outdoor shoes inside. Dirt and sharp particles can cause scratches on the flooring that may become permanent marks. Also, the flooring will be much more difficult to clean if dirt from outside keeps getting tracked indoors. Furniture must have protective pads on the underside and on the legs to prevent scratches on the flooring. If you have to move heavy items across a room, place a thick rug underneath or lift the item if possible, instead of dragging it across the floor.
Step 2 – Refer to Manufacturer Recommendations
Most faux wood manufacturers have recommendations regarding the cleaners of their product. If you use an unsuitable cleaning material, you may void your warranty.
Step 3 – Sweep the Floors Regularly
Use a sweeper or a soft attachment on your vacuum cleaner to remove all the dirt and debris on the floor regularly. In high-traffic areas, do this once every couple of days. In rooms that are not used that often, sweep the floor once or twice every week. This prevents the buildup of grime that can settle into the grooves between the plans and also increase the chances of scratches. Never use cleaners with sharp ends or the beater bars on your vacuum cleaner.
Step 4 – Deep Clean the Faux Wood Flooring
It is preferable to follow every dry cleaning with a mopping session. Keep in mind that the mop must not be dripping wet. This will cause a moist residue on the floor and also leave streaks. Before cleaning, wring the mop so that it is just damp enough for effective cleaning. The most recommended cleaner for faux wood flooring is a mixture of vinegar and warm water. Mix a cup of vinegar in a bucket of warm water. Dip the mop in the solution and wring out most of the water. Mop the floor and follow up with a soft dry cloth immediately afterward.
Step 5 – Remove Tough Stains
Accidents are inevitable and sometimes you may spill juice, sugary drinks, paint or nail polish on your immaculate faux wood flooring. The key to avoiding permanent damage is prompt action. Immediately wipe off the spill and follow up with a warm water and vinegar mix. If there is still some residue remaining, try removing it with acetone. Never use soap-based cleaners, abrasive cleaners or materials like steel wool on your faux wood flooring.
