How To Construct A Crushed Limestone Driveway
Raking out a pile of gravel
  • 12-32 hours
  • 800-2,000
Bobcat with loader
Garden tractor with a rake attachment
Shovel
Hand rake
Crushed limestone
Gravel for base
Compactor
Plastic piping
Transit
Wood stakes
String
Landscape paint
Plastic vapor barrier
Bobcat with loader
Shovel
Hand rake
Crushed limestone
Gravel for base
Compactor
Plastic piping
Transit
Wood stakes
String
Landscape paint
Crushed limestone is a great choice for a material to build a permanent driveway for a new home, or for renovating the current driveway. The crushed limestone is a material that is easy to work with, can be crushed to specific dimensions, and dyed for a wide variety of colors.
While building a new driveway is not something that is normally done as routine home maintenance, this project is well within the parameters of a do it yourselfer's skill set. With some rented equipment, a couple of tons of crushed limestone, and plenty of time, you can construct your own crushed limestone driveway and save a lot of money.
Step 1 - Plan for Everything
When working on a driveway you are essentially building a road. To do that you need to have a lot of different materials and equipment at the time of working on the driveway. The first step is to plan out the driveway itself. Where it is going and what it will look like are the two most important aspects. Use graph paper to draw out the driveway and try to get it as close to scale as possible.
Another part of the planning process is lining up the required equipment beforehand to be available at the same time. This means having the gravel and crushed limestone delivered, renting the power equipment, and even lining up help from friends.
Step 2 - Prepare Land
Rural dirt driveway
One of the biggest rules of building a driveway is to not build it on top of the topsoil. You must remove the soil and build a strong base for the crushed limestone driveway. Outline the shape of the driveway with the landscape paint and mark off the area with stakes and the string.
Using the Bobcat with a loader bucket, remove the soil down to eight to 10 inches, depending on where you live. The farther north, the deeper you need to dig. As you are digging, keep in mind the drainage of water. Have the driveway slope away from any buildings so the water will run away instead of causing potential flooding in basements.
Step 3 - Install Drain Pipes
Once the soil has been removed, and the surface leveled off, spread out the black plastic vapor barrier. Make sure it covers the entire ground area. Lay down the black plastic drain pipes on the bottom of the area you just dug out. They should run the length of the driveway and space at six-foot intervals.
Step 4 - Spread out Gravel Base
rake on a pile of gravel
With the Bobcat, spread out the gravel base over the entire surface area of the driveway. It should be at least six inches deep and cover the plastic pipe. Once it is spread out evenly, use the compactor to pack it tight.
Step 5 - Spread Crushed Limestone
Begin to carefully spread out the crushed limestone onto the driveway. Use a tractor with a rake attachment and smooth out the limestone to a level surface. Compact the limestone, but not as tight as the gravel.
