How to Cut Polycarbonate Panels
  • 1-4 hours
  • 0-500
Power or table saw
Polycarbonate panels are often used to make different things around the house because of its characteristics of being durable, light and not shattering as easily as glass. For all these qualities, polycarbonate does scratch easily, so you’ll have to be cautious when working with it. The most popular polycarbonate sold in the market is the Lexan brand.
Step 1 - Test the Cut
Before you cut a huge chunk of your polycarbonate panel, make sure to do a test cut first. Using an excess piece of polycarbonate, cut it using your table saw or power saw. If the cuts are to your liking, you may carry on with cutting the actual polycarbonate panel.
Step 2 - Modify the Saw
On the other hand, if you aren’t happy with the test cut you can always modify your saw. Adjust the blade in a manner that the word side is facing the opposite side.
Step 3 - Prepare the Panels
Draw a line in your panel to mark the sections you will be cutting off. Cut through that line carefully with the use of your power saw.
