How to Design Plumbing for Wet Bars
12-48 hours
Intermediate
- 200-20,000
Wet bars are a great feature when it comes to entertaining. If you are one of those homeowners who have a huge, unused basement, yet no place to relax and mingle with the neighbors, it’s definitely time for you to set up your very own wet bar. If you can follow instructions, have a knack for home improvement, and the spare time, then a wet bar can be in your immediate future.
Make a Floor Plan
Design a floor plan for your wet bar. Draw in the specific locations of the appliances and furniture that will be located in your wet bar. Also include the water lines in the room you decide to build your wet bar in. Most importantly, trace the position of your new pipes from the water lines to the wet bar.
Tap the Water Lines
Before you go any further, make sure to close your water lines. Look for the section of your water lines that’s closest to the location of your wet bar. Cut into both the hot and cold water lines with a pipe cutter. Expect to get a little wet doing this. Use a T-fitting to remove the sections of the pipe in order to accommodate the new pipes.
Install the New Pipes
If you have already measured and cut out all the plastic pipes that you will be needing for your wet bar and polished them together with the necessary fittings, apply a generous amount of solvent cement on the ends of the pipes and insert the ends into the fittings. Twisting the pipes into the fittings will ensure a tighter grip.
Stub the New Pipes through the Wall
Drill holes through the wall where the bar sink is going to be placed. When you’re done with this and the pipes are all the way through the wall, attach double stops to your water lines. You may now install your faucets and other appliances by connecting through the water lines.
Tap into the Water Drainage
Cut a 2-inch hole into your water drainage pipe and attach a saddle Tee. Cut a hole through the bottom of your wet bar’s sink and connect a pipe or series of pipes from the saddle Tee through it. Attach the drain to your sink.
