How to Determine Bathroom Fixture Dimensions
bathroom sink
  • 1 hours
  • 1-30
Measuring tape
Notebook
Tracing paper and pencil
Measuring tape
Notebook
Designing a bathroom is an involved process, from choosing tiles to picking out paint colors to figuring out bathroom fixture dimensions. You’ll want your fixtures to coordinate throughout the space and to fit into their designated slots as well. There are typical dimensions for tubs, sinks, and cabinets. As you design your bathroom layout, it’s nice to have a general idea of what they are. Knowing how to measure out your bathroom fixtures is an asset as well.
Know Basic Builder’s Fixtures Measurements
Builder’s fixtures have typical measurements you can rely on. They are as follows:
Standard Tub: 30x60x15-inches
Standard Round Toilets: 24x19.5x26-inches
Standard Elongated Toilets: 30.5x19.5x26-inches
Modular Sink Base: 24 to 36-inches wide
Drawer Sink Base: 12 to 18-inches wide
Standard Vanity Base: 12 to 18-inches wide
Know Correct Layout Codes
Check with your local building department to discover what codes are in place in relation to bathroom layout. Make sure all the fixtures have enough clearance around them. For the bathroom cabinet, plan about 30-inches clearance, or more, so that you can open the doors and bend down in front of it. Building codes often call for no less than 20-inches clearance in front of the toilet bowl. Plan for 18-inches to the closest wall or 14-inches to the closest cabinet, measuring from the center of your bowl.
Measure Existing Fixtures
Write the measurements of your current bathroom fixtures in a notebook. Make sure you measure everything with extreme care. To give an example, when measuring a sink that goes into a cabinet, be certain to get the length, width, and depth of your fixture.
Measuring Oddly Shaped Fixtures
If you have an oddly shaped fixture, use a pencil and tracing paper to draw an outline of the unit. That way, you’ll be able to take your drawing to the store when you’re choosing another sink. For something like an odd shower faucet, consider drawing a diagram that you can take with you when you are purchasing replacement fixtures. Take several measurements when drawing the diagram. It’s never undesirable to be thorough.
Think About Size
Though it might seem that you are limited to buying replacement fixtures that are the same size as your current fixtures, that’s not necessarily the case. You can alter drywall, ceramic, or wood materials that might be blocking a new, larger fixture from fitting into place. A smaller fixture than your existing unit, however, might leave a very noticeable gap in flooring or wall material. Be sure of the fit before you commit.
