How to Determine if Your Ceiling Insulation is too Old
If you are trying to decide if your ceiling insulation is old and needs to be replaced, there are several things that you can keep in mind to make this important decision. You want to always make sure that the insulation in your home is up to date and safe. Here is a quick guide to help you.
Consider the Age
Insulation, like many other goods and materials, has changed in the past few years. If you live in a home or you have not replaced your insulation in the last 15 to 20 years, then you will want to consider an update. One of the biggest reasons why you should replace old insulation that has aged more than 15 years is because it will save you a good amount of money.
Too Much Insulation
It was common years ago to think that having more insulation in the attic or ceiling was much better. Now though, we know that it is important to have enough, but not go overboard so as to restrict the airflow in the ceiling as well as the ventilation. So if you find that there is way too much insulation, this may be because it was put in too long ago and needs an update.
