How to Finish Stock Kitchen Cabinets
  • 24 hours
  • 125
Knobs and pull handles
Fine sandpaper
Stain
Staining brush
Rags
Tack cloths
Varnish
Brushes
Drill and 3/16" bit
Screwdriver
Fine sandpaper
Stain
Staining brush
Rags
Tack cloths
Varnish
Brushes
Drill and 3/16" bit
Screwdriver
If you are building a new kitchen or remodeling an old one, you may need some ideas on how to finish stock cabinets. Using stock cabinets can save you money on your project. Finishing them can take a bit of time, but the savings are worth it.
Step 1: Finishing and Trimming cabinets
If your cabinets already have a finish on them but are very plain, then you may want to dress them up a bit by applying drawer pulls, cabinet handles, plate rails, and decorative moldings. One of the most commonly used wood in kitchens these days is oak. For oak cabinets, knobs and handles in black, stainless steel, or white is a popular choice among designers. Of course, this is all a matter of taste so don't be afraid to experiment. Installing them is very easy, all you need is a drill and screwdriver. The instructions and template are usually included in the package.
If installing a crown molding around the top, if you don't have a bulkhead, you will want to match your cabinets, or perhaps paint the molding in a color used in your kitchen for a decorative effect. For molding, think in the terms of placing an empty picture frame in the center of your cabinet door. You will need a miter box, decorative molding, a nail gun, and a bit of carpentry skill to do this.
Step 2: Finishing unfinished cabinets
Unfinished stock cabinets are usually the best buy when you are upgrading your kitchen. Most commonly, they are made of particleboard lined with an enhancing wood veneer and may actually be more sturdy than the finished, custom styles.
If you want to stain your cupboards you can test various stain colors to get what you want on the backside of them that will be against the wall when installed. Use at least two coats or more to get the true color. Sand your cabinets with very fine-grit sandpaper, such as 150 to get them satin smooth and rid of bumps, splinters, and imperfections. This also opens up the wood so the stain can penetrate. Wipe away all sawdust with a tack cloth.
Use a brush designed for stain and apply the stain all in the same direction with the grain of the wood. Cover the entire area and let it sit for a few minutes. Then wipe away gently with a soft, dust-free cloth. Continue this until all the surfaces are finished. If you want a darker shade, wait 24 hours and re-apply. Then let the cupboards sit and dry for a couple of days.
Step 3: Applying Varnish
Once the stain on your cupboards is completely dry with the right color shade, wipe with a tack cloth to remove all remaining dust from the wood surfaces. Then apply at least two coats of varnish using the manufacturer's instructions on the can. Apply with brush strokes in the direction of the wood grain, always in the same direction. Do not shake the can of varnish before applying because it will create bubbles in your finish. Be sure to always stir varnish.
Step 4: Finishing up
After the project is dry, you can install knobs or handles per the above instructions for a more finished look. While this project will take you several days to complete, the savings will be well worth the effort.
