How to Fit Up and Over Garage Doors
man installing garage door
  • 2-4 hours
  • 100-500
Tape measure
Marker
Hammer drill
Masonry bit
Lumber
Hammer
Nails
Step ladder
Screwdriver
Socket wrench
Tape measure
Marker
Hammer drill
Masonry bit
Lumber
Hammer
Nails
Step ladder
Screwdriver
Socket wrench
Up and over garage doors are different than the normal style doors that have sections and rollers. They're usually composed of one piece situated on a frame. When you lift one of these doors, the entire door tips out, then up, and over the head. These doors are good for security, but they're not very DIY friendly. One of the main problems with installing the up and over garage doors is the actual fitting of them.
Step 1 - Determine Which Type of Door to Purchase
There are two basic types of up and under garage doors. One is the canopy style. This door is mostly used for a single-car opening and does not reach any higher than 8 feet. The other drawback to this type of door is that it is not connected to an automatic door opener.
The other type of up and over garage door is called a retractable door. This door can be much larger and mechanized for automatic opening. Before installing the door, you must first determine the type that will work in your application.
Step 2 - Take Accurate Measurements
Up and over garage doors are mostly installed within a subframe. This means that the door can be installed either inside the actual garage door opening or directly behind it. Accurate measurements are needed to make sure that the door you order will fit perfectly.
Step 3 - Realize What Measurements Mean
When taking measurements to fit up and over garage doors, you must know what they mean. An up and over door is sold by a certain measurement. This is the actual space between the subframe. For example, a 7x7-foot garage door refers to the space between the subframe rails and from top to bottom. The actual garage door measurements will be different for ease of operation.
Step 4 - Fit Frame in Door
Once you have the new up and over garage door you need to fit it into the opening. Position the subframe railings on the side of the garage door frame. Mark the location of the bolt holes for the mounting bracket.
Step 5 - Install Frame
Drill holes into the concrete opening where the holes were marked. Use a hammer drill when drilling into concrete. Set the frame rails back into position and secure with the bolts.
Step 6 - Build Brace for Top Rail
A retractable up and over garage door is going to need to have the top rails secured to braces from the ceiling. You can build this easily through scrap lumber or metal tubes.
Step 7 - Connect Top Rails
Hold the top rails up against the support brace and drive in the lag bolt to hold it into position. Secure the rail to the vertical rails with the hardware provided. Make sure it is level and secure the top railing permanently.
Step 8 - Install Door
Hook the springs into the lifting mechanism and set the door into place.
