How to Fix Squeaky Floors
Lead Image for How to Fix Squeaky Floors
  • 1-2 hours
  • 50-90
Hammer and flooring nails
Screws (square headed: 1 1/2 to 2 inches long)
Shims
Stud finder
Talcum powder
Powdered graphite
1 by 4 lumber for bracing or blocking
Shims
Stud finder
Talcum powder
Powdered graphite
Unnecessary noises coming from your house can be quite annoying such as squeaking floorboards, so it is helpful to know how to fix squeaky floors to relieve yourself of the noise. Wood tends to dry out and shrink in size as the year goes by. This drying and shrinking cause little gaps to form in between floorboards. Loose floorboards and loose nails are two of the most common causes of a squeaking floor. Below are the materials that you need along with the instructions on how to fix squeaky floors.
Apply Talcum Powder
Sprinkle some talcum powder or powdered graphite on the seams of the squeaking floorboards. After you finish applying the talcum powder, cover it with a paper or cloth towel. Step on the covered areas a couple of times so that the powder seeps through. The talcum powder should provide lubrication in the middle of the squeaking floorboards.
Secure Floor Boards into the Subfloor
If you still hear some squeaking after the first step, this means that you will need to secure the floorboards tighter onto your subfloor. Other than creating the squeaking, loose floorboards can be rather unsafe.
Install Flooring Nails
Use 6d or 8d flooring nails and install these at about 1/2 an inch from the edge of your floorboard. These should be nailed all the way down to the subfloor. To protect your floorboards from cracking or splitting, drill smaller holes before nailing. Using wood filler, patch the nails so that they have the same color as your floorboard and do not attract much attention.
Use Small Screws
You can also use small-sized screws to tighten the floorboards in place as these work better than nails. After securing the screws, patch the wood screw with wood fillers.
Secure Loose Joists
Examine the floor joists and cross bracing. The squeaking is probably caused by loose joints. Securely fasten the floor joists with screws.
Install the Shims
You can place shims on top of the floor joists. This should be done under the floorboards. Press down on the shims to secure them in place, but avoid hammering them in place as this may cause the floor to be pushed up from underneath.
Install Extra Screws
You can also try installing extra screws to fasten the floor joists. Make sure that the screws are placed in an angular direction.
Install Bracing
You may also install extra bracing in the middle of the floor joists. This should measure 1 by 4 inches. Install the bracing securely in place on the subfloor. Use screws that are long enough to secure it through the subfloor, but not too long to penetrate the floorboards.
