How to Get Rid of Crickets in Your Home
  • 1 hours
  • 20
Molasses
Water
Diatomaceous earth
Sugar
Jar
Knowing how to get rid of crickets in your home can save you many sleepless nights. There is nothing more irritating than the symphony of crickets coming from inside your house. Read this article for advice on getting rid of crickets.
Identifying a Cricket
Crickets are brown or black with long antennae. They have wings, but don’t usually fly. The wings lay flat against their body, except when the male lifts its wings to scrap one against the other to make a chirping sound. This sound is made to grab the attention of a female cricket. The female cricket hears the chirping through eardrums located on her front legs. Crickets are capable of jumping up to 3 feet, which makes crickets difficult to get rid of.
Reasons Why Crickets Like Your Home
The most common types of cricket found in homes are the house, field, and camel cricket. A camel cricket looks like a bad experiment and it’s not a pleasant experience to come across them when you turn on the light. Crickets are drawn to your home because they can find an unlimited food source with little worry about being prey for something else, and they like humid, dark places. Outside your home, crickets are food for spiders, wasps, beetles, reptiles, birds and rodents. Continue reading for advice on getting rid of crickets.
How Crickets Survive in Your Home
Crickets are omnivores, meaning they eat both plants and animals. Nonetheless, crickets actually will eat anything, and they even consider decaying plants and insects appetizing. They will also ingest seeds, fungi, wood and cloth. To get rid of crickets, stop feeding them.
Protecting Your Home from Crickets
By taking preventative measures, you can get rid of crickets. Check your basement walls and house foundation for any cracks or holes where crickets can enter. Seal any openings you find. Rake leaves, trim bushes and keep the grass cut around your house so crickets don’t use the area for shelter. Gutters should be routinely cleaned so leaves don’t have a chance to decay and create an ideal spot for crickets to live. Bright outdoor lighting at night attracts crickets, so switch to bulbs that emit a low yellow light. Discard clutter in your basement to eliminate hiding places for crickets if they do get into your home. Call an exterminator and have the perimeter of your home sprayed yearly with a pesticide to keep away crickets.
There are some things you can do to get rid of crickets in your home. An easy homemade trap consists of a jar filled with water and molasses. Crickets will jump into the jar to get to the molasses and drown. Glue traps catch crickets when they walk across them and get stuck. Diatomaceous Earth is a product that is nontoxic to both humans and animals, but deadly to crickets. It works to get rid of crickets naturally instead of chemically. Prehistoric fresh water Diatoms created miniscule shells that became fossils. These fossils are dug up and ground into the Diatomaceous Earth powder. Sprinkle it around your basement or garage, in cracks and cervices, and behind appliances. When the crickets come in contact with the powder, it penetrates their exoskeleton to dehydrate and kill them.
