How to Hang a Heavy Mirror
1 hours
Beginner
- 0-50
Hang a heavy mirror if you want your room to appear larger than it is. A large and heavy mirror hanging at your wall will not only make your room seemingly more spacious but it also serves as a light reflector convenient for rooms with small windows.
Hanging a heavy mirror is not a difficult task. However, it requires assistance from a friend, especially if the weight of the mirror is greater than what a single person can lift or carry.
Step 1 - Examine the Mirror
Examine the heavy mirror and determine if it has a frame. Make sure the screw eyes on the frame are firmly secure. Check the picture wire if it is firmly twisted at the screw eyes.
Step 2 - Position the Mirror
Look for an ideal place for your heavy mirror. With a pencil, determine the center of the heavy mirror and mark two adjacent spots. Make sure that the two marked spots are level to each other.
Step 3 - Locate the Studs
With a stud finder, determine if there is a stud behind the two marked spots you made on Step 2. If there is a stud behind the two marked spots, drill a pilot hole on each spot with a drill bit that is slightly smaller in diameter than the wood screw you are using. Insert the wood screw into the pilot hole and tighten using a screwdriver. Do not screw the wood screws all the way into the wall. Make sure there is at least one inch of protruding wood screws which will serve as the hanging point for your heavy mirror. Place the heavy mirror on the wall and make sure the picture wire is firmly attached to the wood screws.
If there is no stud behind your two marked spots, you can either reposition your heavy mirror location until you find a stud underneath your marked spots or use toggle bolts. Toggle bolts are perfect for hanging heavy objects on drywall.
Step 4 - Hang a Frameless Mirror (Optional)
For frameless heavy mirrors, install mirror clips. Mirror clips are clear plastic clips that can withstand the weight of heavy mirrors. Mark and measure the bottom portion of the heavy mirror and use a level to make sure the heavy mirror is positioned straight and level on the wall. Mark the two spots with a pencil. Mark another two spots, this time mark the top area of the heavy mirror where the two mirror clips should be installed.
Using a stud finder, determine if there is a stud at your mark spots and then drill a pilot hole on each marked spot. Attach long wood screws in the holes and then attach the mirror clips on the wood screws. Attach the heavy mirror on the wall with the mirror clips. Make sure the heavy mirror is level before tightening the mirror clips.
