How to Install a Basement Drain
basement drain
Water conduits with water guard ports
Jackhammer
Crushed stones
Concrete mix
PVC pipes
Electric
Sump pump with a liner
Electrical wire and connectors
Shovel
Pliers
Wheel barrel
Levels and straight edges
Trowels
A house with no drain in the basement could become a huge problem to a home owner. Water may infiltrate through the concrete walls in the basement if the yard outside is not properly drained. Large amounts of rain, or a fast snow melt in the spring, could flood your basement. Understand that installing a basement drain in your home is a major job that can be costly, but necessary to avoid even more expensive damage caused by mold and more flooding problems.
Step 1 - Level the Basement Floor
The first thing to do is to level the basement floor at an angle so that water will run to the same place. The floor should be higher around the room near the walls and lower in the place where the drain will be installed.
Step 2 - Install Your Drainage Conduit
A water conduit must be installed around the inside of the basement wall so if there is any infiltration coming from the walls, the water will run down the conduit to the drain. Use crushed stones to bring the conduit to the correct elevation. The conduit should include some water guard ports, also called inspection ports. Ports serve as a trap in the middle of each conduit that protrudes above the finished concrete floor. They allow you to make sure the system is working well.
Step 3 - Install the Sump Pump
A hole large enough to receive the sump pump will have to be carved. Cover the bottom with crushed stones before placing the pump in the hole. Set the included floor drain at the height of the finished floor and connect the wires from the pump directly into the house wiring.
Step 4 - Install Discharge Pipes
Connect at least one discharge pipe which runs from the pump to the outside. Make sure the discharge pipe has ice guards. Ice guards prevent water from backing into the house during the winter months.
