How to Install a Galvanized Steel Fence
A galvanized steel fence is one of the most common fortifications that can be used, particularly for means of safety. Installing a steel fence is not complicated if you obtain the correct tools and have an idea of how to handle the entire process. Here are the steps to erecting a galvanized steel fence.
Step 1: Choose the Galvanized Steel Fence
There are various types of fence, so it is important to know which one best suits your needs. When a fence is galvanized there is extra protection applied to the steel to avoid the problematic rust that could develop otherwise.
Step 2: Start Digging
Dig a whole approximately 3 feet by 2 feet, using the hole digger and a shovel. The general rule of thumb is that roughly 1/3 of the post should be in the soil.
Step 3: Use Rust Inhibitor
Scatter rust inhibitor around the sector of the steel fence post that will be beneath the ground level.
Step 4: Position the Steel Fence
Place the galvanized steel fence post in the hole. Determine the length of the post with the measuring tape to ensure that it is stable with the height of the other fence posts. You can also use a leveling tool. Add or reduce soil so as to raise or lower the post. Attach the terminal, or corner, posts first when installing steel posts for fence. Run a line on one side of the terminal posts. Align the side of the line posts to handle the line from one side of the terminal posts so the fence will not be crimped.
Step 5: Fill in the Gravel
Load the opening with about 6 inches of gravel around the fence posts. You can then fill the rest of the hole with some soil. Finally, push downwards so as to make it more compact using the flat edge of a sledgehammer. Add the soil in 2 to 3 inch layers and use a level to ensure the posts are plumb between each coating.
Step 6: The Concrete Mix Addition
Combine concrete with water in a wheelbarrow. Mix systematically with a shovel. Follow the instructions supplied with the concrete you purchased in order to mix it well.
Step 7: Mix Concrete into the Gravel
Scoop the concrete into the gap around the steel fence. Work the concrete mix into the gravel with the cutting edge of the shovel.
Step 8: Verify the Correct Position
Position the level on the side of the fence and verify that the post is plumb. Revolve the level around the steel fence post to make sure it is plumb on each side.
Step 9: Let it Set
Strut the steel fence in position or hold it until the concrete has begun to rest and will grasp the fence without assistance. At that point the fence posts should be securely and steadily fixed in the ground and your galvanized steel fence is ready.
