How to Install a Kitchen Hood
4-12 hours
Beginner
- 200-500
Installing a kitchen hood is a great way to get rid of fumes and smells while cooking. In addition to this useful functionality, range hood vent will add decor, as well, to your kitchen. You can easily buy a range vent hood from any of the appliance retail outlets. Though you can buy a hood of any of the available styles, the installation process for all of them is the same.
Step 1 – Lay out the Duct
The first decision that you need to take is choosing whether to rout the exhaust through the roof or wall. Obviously, if you live in a brick veneer home, you don’t have any choice other than to use the roof.
Step 2 - Purchase the Duct
Once the duct plan is laid out, purchase the ducting to match the route. As most vent hoods use a square duct at the top, and most duct for purchase is round, be sure to get an adapter for the transition.
Step 3 – Empty the Hood for Installation
From range hood, remove the fan and light assemblies and filter. Also remove the vent knockout and the electrical cable.
Step 4 – Mark Knockout Location
Hold the hood over your stove in the position you intent to install it. Mark the location of the knockout with a pencil so you know where to cut the cabinet to pass the duct through.
Step 5 – Cut Hole
Cut out a hole for ventilation duct in the inside of cabinet. Repeat though the top of the cabinet and ceiling or wall until you reach the outside.
Step 6 – Install the Duct
Install the duct by placing the pieces together. linking the holes in cabinet to holes in the wall/roof. Following this, tape the pieces together.
Step 7 – Use Adapters
For most of the hoods, square ducting runs from them to the round ducting which is used for fitting in vent roles in roof or wall. To enable this adaptation, you will need to use the adapter.
Step 8 – Connect Wires
Connect the white wire from hood to white wire on the wall. Similarly, connect the black wire of hood to black wire on the wall.
Step 9 - Ground the Hood
For safety, it is important to ground the hood. Wrap the green wire on wall around the screw (ground) on exhaust hood. Tighten the screw to secure the connection.
Step 10 - Cable Clamp
Fix a cable clamp on the wires at the place where they meet the exhaust hood assembly. Tighten them using a Phillips screwdriver. Push the wire to the access compartment.
Step 11 – Test the Hood
Install back the light and fan assemblies and also the filter and secure all electrical connections. Switch on the power to the hood to test its working.
Step 12 – Seal the Flange
Use roofing tar or caulk to seal the vent pipe flange. Do not forget to slip the flange under the shingles of upper roof before you begin to seal.
