How to Install a Paver Walkway on a Slope
red paver walkway on a slight slope surrounded by greenery
  • 8-80 hours
  • 100-4,000
Pavers
Crushed rock
Compactor
Landscape paint
Sod cutter
Landscape border
Shovel
Rake
Gloves
Paver walkways add character and definition to your landscape, garden, entrance area, or backyard path. There are plenty of different pavers to choose from, and installing them isn’t difficult when you have the right technique. However, installing pavers on a slope is slightly more complicated. Use this guide to begin.
Step 1 - Determine the Walkway’s Location
Before working on the sloped area, you must decide where you want the pathway to be located. Mark the outline of your walkway with landscape paint and choose an area with the least degree of slope possible. The more level the area is, the easier this project will be to complete.
Step 2 - Prepare the Ground
Once the ground has been marked with the paint, you can prepare it for the pavers. Use a sod cutter to cut through the sod and leave it in lengths you can roll up and transport to other areas of your lawn. Once the sod is up, remove any rocks, roots, or other obstacles left.
Step 3 - Rake the Ground
Raking dirt level
To finish preparing the ground, rake it until it’s smooth and even. If you skip this part of the step, any depressions and holes left can hold onto water, which will weaken the foundation of your walkway.
Step 4 - Install a Border
Install a landscape border of your choice. Small, plastic borders that have a curved reveal are good for defining your space and giving you a reference point when edging your lawn. Set the border on the side of the area that has been cut out. Drive the stakes in to hold it in place.
Step 5 - Spread Crushed Rock Over the Ground
With the soil prepared for the pavers, spread out a layer of crushed rock onto the ground that’s two-inches deep. Smooth it with a rake, and then run over it with a compactor to make a solid surface for laying the pavers.
Step 6 - Install Your Pavers
installing paver stones
Starting at the bottom of the walkway, lay out your pavers. Start in the center of the walkway and work out to the sides. If you need to cut any of the pavers, use a chisel to score them. Break the piece off with a hammer. Continue installing the pavers until the walkway is completed.
Step 7 - Spread Sand Over the Pavers
To cement the pavers in place, use concrete sand. Spread the sand over the top of the bricks, sweeping the sand into cracks and crevices. Use the compactor again to ensure your work is level.
Step 8 - Wash Away Excess Dirt
Finally, turn on a hose and spray it on your walkway to remove any standing dirt left on top of the walkway.
