Screw Drive Garage Door Opener Installation
empty garage with door open
  • 250-500
Screw-drive garage door opener
Angle iron
Electrical wiring
Reinforcement brackets
Screws
Stud finder
Bolts
Flat blade screwdriver
Philips screwdriver
Hammer
Hack saw
Level
Pliers
Adjustable wrench
Step ladder (6’ to 7’)
Wire stripper
Safety glasses
Tape measure
Pencil
Electrical drill
Metal cutting snips
Angle iron
Electrical wiring
Screws
Stud finder
Bolts
Philips screwdriver
Hammer
Hack saw
Level
Pliers
Adjustable wrench
Wire stripper
Safety glasses
Tape measure
Pencil
Electrical drill
Metal cutting snips
A screw drive garage door opener uses a threaded steel rod along which the lifting mechanism travels. Generally it is considered to be reliable and durable and requires a minimal amount of maintenance. If you decide to install the garage door opener yourself, make sure you go through the user manual before beginning, as each door opener has its own specifications; below is a general guide to a screw-drive garage door opener installation.
Step 1 - Create a Pre-installation Checklist
Before beginning measure the height, thickness, and type of door and the overall size of your garage. These specifications are prerequisites to buying the appropriate garage door opening unit for your needs. Before you begin installing, undo locks and clear out the garage.
Step 2 - Assemble the Screw-Drive Garage Door Opening Unit
garage door opener unit mounted to ceiling
Your screw-drive garage door opener is a three piece unit (for the majority of the brands available). For assembly, it is best to read the instruction manual and follow the directions. The manual will also provide you with the basic instructions on how to install the unit as per your door type. Assemble the pieces and lay them out on the garage floor.
Step 3 - Mark the Center and Take Measurements
The motor head should be horizontally centered in proportion to the garage door, so measure the door and divide the length to find the center. The distance at which it should be placed depends on the height of the door. For a 7’+ door, the average distance will be about 10 feet.
Step 4 - Install the Reinforcement Brackets and Attach the Power Head
Use a stud finder to find the stud along the marked measurements and attach perforated angle irons to form an ‘L’. For a sectional door, the motor should be placed slightly below the level of the door. At the lower end of the ‘L’, attach the motor. The remaining unit will extend from it.
Step 5 - Secure the Door Arms
garage door opener button with wiring
For a sectional door, attach the shorter legged arm to the door bracket, and the straight arm to the carriage. Connect the two using a clevis pin and a cotter pin. The two brackets will be connected using bolts. Make sure you space the bolts. The length of the arm should be as short as possible but should not be vertical when the door is fully closed. The carriage can be moved and the bolts re-adjusted to get the proper length. Adjust the emergency release knob according to your requirements.
Step 6 - Connect to an Electricity Outlet
You need to have an electric outlet within a three-foot range of the motor. You should not use an extension-wire as it is a potential violation of the safety code.
Step 7 - Install Infrared Security Devices
The device is attached to both ends of the bottom of the door using brackets. While attaching, make sure the red LED is placed on the side that gets the most sunlight. The device is a security device to prevent accidents.
Step 8 - Finish Up
Install the wall controllers as per instructions. Plug the motor into a socket and test the door.
