How to Install a Shower Wall Vapor Barrier
4-8 hours
Intermediate
- 200-450
If you are a homeowner worried about the proper maintenance of your house, you should definitely consider installing a vapor barrier on your shower wall and following the following tips.
Vapor barriers protect the overall construction from damage caused by condensation and moisture intrusion in the form of active leaks that can cause mold colonies to start forming and growing behind the scenes, unseen. The barrier blocks water, preventing it from reaching the structural frame. A barrier prevents the leakage of air through the walls, helping you manage the interior temperature better. You can easily install vapor barriers at home in order to avoid common problems caused by humidity, condensation, and steam. Now you can install your own vapor barrier in a few easy steps.
Preparation
Remove the materials of the existing shower wall. These materials depend on the age of your bathroom, but in most cases, you will find drywall or lath and plaster. Removal is not difficult if you have a metal wrecking bar. If there are any windows, gaps, or doors, caulk them before starting with the installation. Check the wall cavities for rot or mold. If there is any mold, treat it with bleach and let the wall dry overnight.
Rolling the Barrier
The next step is easy; take the vapor barrier roll and roll it on the wall. It should be 2-inches below the footing. This will prevent water from seeping into the floor when it settles on the barrier. Make sure that you place a double layer of the barrier on all joints because the joints are the vulnerable part of the barrier.
Attach the Barrier on the Wall
Nails or staples the barrier to the studs, keeping a 2-foot space between attachment points, to make sure that the barrier stays in place. Seal the seams using seam tape, which is specially designed for this use. Do not use any other type of tape, because you might allow the seepage of water, compromising the seams. Make sure that the plastic sheet is attached snugly to the studs of the wall so that you can smoothly install the wall materials over it.
Extra Tip
Use a polyethylene plastic which is specifically designed for residential installations of vapor barriers on walls. Be careful when installing the barrier because its improper use might cause additional moisture problems. Placing a vapor barrier around the shower wall will ensure a long-lasting installation, but only if installed properly. Apply the barrier and then install cement boards to complete the wall. Do not use drywall or greenboard over the vapor barrier. These materials will not withstand the moisture trapped by the barrier. The cement board breathes and will allow moisture to pass through to the vapor barrier and then evaporate back out through the cement.
