How to Install Faux Brick Paneling
gutter downspout on wall with faux brick paneling
  • 2-3 hours
  • 30-300
Faux brick paneling
Screws (drywall screws for indoor application)
Screwdriver
Caulking gun
100 grit sand paper/sanding block
Hack saw
Measuring tape
Painters tape
Pencil
Construction adhesive
Protective gear (glasses and gloves)
Faux brick paneling
Screwdriver
Caulking gun
Hack saw
Measuring tape
Painters tape
Pencil
Faux brick paneling is manufactured in sheets that look and feel like real bricks but aren't. They are generally available in sheets ranging in size from 24/36 inches to 24/48 inches, depending on the manufacturer.
Installing faux brick paneling is easy, and you will require a dozen or so sheets for one wall (depending on the size of your wall). You can use it for both interior and exterior finishing.
Step 1 - Taking Necessary Precautions
Always wear protective gloves and glasses when using a saw. If need be, you can get the paneling cut according to the measurements of your wall on pre-ordering at the store, this might cost extra, but it is worth it if you do not have the necessary equipment.
Step 2 - Measuring your Walls
Before purchasing your paneling, you need to measure your walls to know how many sheets you need to buy. Always buy slightly more than you need if a panel is damaged during application and needs to be replaced.
Step 3 - Cutting the Faux Brick Paneling
Cutting the paneling is easy and is required for edges and trimmings.
Measure the wall.
Place the paneling face up on a flat surface with the portion to be cut off hanging from the side.
Stick the painter's tape and draw a straight line. Using a hack saw, cut along the line.
Once that's done, remove the tape.
Step 4 - Sanding the Cut Edges
The sawed edges will require sanding. Using the 100 grit sandpaper or a sanding block, carefully sand the edges to give a neat, finished look.
Step 5 - Using Adhesive to Put the Paneling in Place
Using the construction adhesive on the back of the paneling, place the paneling in place on the wall. Always start from the inner bottom corner of the wall and move layer upwards by layer.
Step 6 - Screwing the Paneling for a Firm Hold
Locate the screw holes you can mark on the paneling before beginning if it does not come with already drilled holes at the edges. Using the electric/manual screwdriver, screw the faux brick paneling in place. This will give the paneling a strong hold with minimal chances of falling off.
Step 7 - Caulking the Screw Holes
Use a caulking gun to fill out the screw holes. Make sure that the caulking material matches the color of your paneling. You can mix the color by yourself if it is not available in the market.
Step 8 - Finishing Up
Using the caulking gun, fill out any uneven edges which don't fit properly. Use sandpaper to sand the caulk to give a neat, finished look. The final look should resemble that of a real brick wall. Make sure you clean up the work area before marking the job as complete.
