How to Install Metal Siding
exterior metal siding
  • 24-60 hours
  • Advanced
  • 2,000-15,000
Tape measure
Hammer
Galvanized 2 inch nails
Paint scraper
Wedges for filling in depressions
Underlayment: perforated, aluminum foil type
Staple gun and staples
Sheet metal siding
Starter strip
Corner caps
Paint
Paintbrushes, rollers, and trays (optional)
Protective clothing
Eye protection
Gloves
Tape measure
Hammer
Paint scraper
Sheet metal siding
Starter strip
Corner caps
Paint
Protective clothing
Eye protection
Gloves
Metal siding is a great alternative to shingles or wood, in that it is more durable and requires less maintenance. Once installed, it will be easy to maintain.
Newer metal siding is not only fireproof but also dent-resistant. It has an impressive look and allows for better curb appeal. It is also energy efficient.
Tip—Be sure to choose a siding that will resist leakage from rain and that comes in sheets for easier installation.
Step 1 - Prepare to Install the Siding
metal corrugated siding
Before you can begin installing the metal siding, determine how much siding you will need to purchase by measuring the entire area to be covered.
You also need to check the walls. If you find any nails, simply hammer them all the way into the wall or remove them using the claw end of a hammer.
Replace any rotted wood, clean off any paint or debris with a paint scraper, and fill in any depressions with wedges.
Good preparation work will lead to a better-finished job and is one of the most important parts of any DIY process.
Step 2 - Install the Underlayment
Attach the waterproof underlayment to the house using a staple gun. Be sure to pay special attention to edges near any openings, such as doors and windows.
Also, attach the lining at the corners well. Overlap edges of the underlayment by at least two inches.
Step 3 - Install the Siding
Installing metal siding
First, install the strip around the bottom of the entire building securely so the sheet metal will slip under it easily.
As you install the sheet metal siding, be sure the panels are lined up straight. This is the most important step in the whole project in order to keep rain and snow from seeping under the metal siding.
Overlap each sheet by at least two inches. When installing each sheet, hammer the nails into the precut holes. Do not hammer down the nails too tightly, and don't hammer them less than six inches from the overlaps.
Be sure to leave a 3/4-inch gap at the corners. This is necessary to be able to install the corner caps.
Step 4 - Install Corner Caps
To install the corner caps, slide the rims under the appropriate sheets of metal siding. Hammer nails into the caps to ensure the siding and caps are secured firmly together.
Metal siding can be painted to match the home's color scheme if desired. This practice would add another element of curb appeal. Whether or not the sheet metal siding is painted, it will create a more energy-efficient home that looks nice.
