Mirror Tiles Installation and Creative Ideas
2-6 hours
Beginner
- 200-300
Add the feeling of extra space and bring more light to any wall in your home with the addition of mirrored tiles. As well as acting as a great light reflector, mirror tiles are fantastic for creating the impression of extra room, and they look great in bedrooms, kitchens, or bathrooms.
Choosing Your Design
Decide in advance on the pattern you intend to use. The possibilities are limited only by your own imagination and the various ideas you can come up with.
Mirrors show us our reflections, but they can also be used to decorate, whether updating a bathroom or adding romance to a bedroom.
There are lots of ways to find inspiration for tile patterns using various ideas, whether you draw inspiration from history, nature, or design trends. Look at pictures of interior design and refer to historical designs to get ideas and come up with your own unique tile patterns.
Choosing the right pattern will also help you purchase the correct number of mirrored tiles, so you end up spending only what you need to spend to complete your vision.
Creative Ideas for Mirror Tile Patterns
There are all sorts of ways to use mirror tiles to bring light into any space of the home. There are lots of options for different types of mirror tiles, too.
While you're thinking about places to put mirror tiles, think also about the style of mirror tiles you want. Large block tiles, diamond shapes, and geometric tile styles are common.
However, you can also experiment with mosaic mirror tile designs and other more creative and unique types of tile while you think about ways to stylishly add mirror tiles to your interior design. Take a look at the different mirror tiles available because just looking at them might give you more ideas.
Kitchen Backsplash
Make your kitchen look bigger and brighter by adding rows of mirror tiles to your stove or sink backsplash area. This is the space directly behind the stove or sink in the kitchen.
Besides looking pretty, the mirror tiles will bring reflected light into the kitchen and brighten up the entire space.
The area under the cabinets behind the counter is often dark and shadowy. Mirror tiles change this by bringing light into this usually dim area.
Decorate the Garden
Place small mirror tiles onto terracotta flower pots. Whether you keep the pots outside or in the garden, they will liven up the surrounding space.
The little mirror tiles will catch and reflect light, bringing a little bit of sparkle into garden areas. You can use this trick for raised flower beds, too.
Accent Wall or Strip
Add mirrored tiles to a wall or to a section of a wall to create an interesting focal point for the space and add an interesting element. Many people use some big design element to create drama in space, but a mirror tile wall is one way to do it easily and affordably.
Try adding mirror wall tile in a large space on the wall, such as a rectangle or circle, or try placing them down the wall in a jagged slash. There are lots of ways to get creative with this idea, so stretch your mind and let your thoughts roam free.
Behind the Bed
Add mirror tiles to the wall behind the headboard of your bed, or use this instead of a headboard, to add depth to the space and make the bed even more of a focal point of the room.
Update Furniture
Adhere small mirror tiles onto an old bedroom dresser that has seen better days. You don't even need to strip the furniture of the paint, just attach craft mirror tiles where you want them.
Your dresser will take on a new look in less than an hour of work. This quick fix updates any piece of furniture, hiding worn areas and giving it an instantly modern appeal.
Beauty in the Bath
Use mirror wall tile behind the bathtub to create the illusion of space. Mirror tiles are also easy to keep clean, which makes them a welcome addition in the bathroom area.
Sky High
Attach large mirror tiles to the ceiling of your bedroom, which will make the room look larger and brighter. When the sun enters through the windows, the entire room will shine.
This is a great trick for sprucing up a ceiling that has seen better days and for bringing more light into a room of the home that is often lacking in light.
Accessorize, Accessorize
Adorn picture frames and mirrors with small mirror tiles to hang in your home. You don't have to worry about having matching frames if you cover them with mirror tiles.
The mirror tiles give frames a modern look that also helps draw the eye to artwork and mirrors hanging in the home.
Illuminate Rooms
Use mirror tiles on walls behind displayed candles, which will illuminate the candlelight. You can also install mirror tiles behind scones and wall light fixtures to reflect more light and brighten up spaces easily.
By adding mirror tiles around existing light fixtures, you practically double the amount of light in the room without actually adding more lamps.
Mirror Tiles Installation Guide
Installing tiles sounds positively terrifying, like one of those neverending DIY projects you can never quite complete. But actually, mirrored tile is incredibly easy to install and requires very little by way of maintenance once they're in place.
Mirror tiles are fun to use and can be purchased at most home improvement and craft stores. They are inexpensive, easy to work with, and are often boxed and ready to install.
Step 1 – Measure
Measuring the wall you're going to tile is an important aspect of this procedure. Getting the correct measurements will eliminate the possibility of purchasing too many tiles for the job, or not enough.
Record the total height and width of the wall in question and work out how many mirror tiles will be needed to completely cover the area. This, of course, is based on how large your tiles are.
When you purchase tiles, the size of the tiles will be clearly marked, so you know exactly the size of mirrored tile you have.
Step 2 – Clean and Prep the Area
Before adding mirror tiles to a wall, it is important to make sure that the old surface is clean. Scrape off any loose paint or wallpaper before starting this project.
Once the surface is prepared, drop a plumb line down one side of the wall and mark the straight edge with a pencil. You need to establish a straight line in order to correctly install tiles.
Step 3 – Placing Tiles
Place five small pieces of heavy-duty double side tape onto the backside of each mirrored tile, with one piece in each corner and the last piece in the center of the tile.
Remove any backing from the double-sided tape and place the tile with one edge aligned against the straight line. Press firmly to the wall to ensure good adhesion.
Wear safety gloves the entire time you're working with mirror tiles to avoid potentially sharp edges that could cut your hands.
Step 4 – Work in Columns
Continue adding additional mirror tiles to the wall, working in vertical columns and starting from that straight line. The second tile should be added over the first tile, the third over the second, and so on, until a column is completed.
The second column should begin adjacent to where the first column began. Continue using this method until the wall is complete.
Step 5 – Cutting Tiles
Installing mirror tiles is not difficult, but for a professional-looking finish, you must ensure that the mirror tiles are cut correctly.
If the need to cut a mirror tile arises, simply score the glass using a glass cutter. You will do this by running the glass cutter against a straight edge and snapping off the piece of glass, gently, for a perfect edge.
Measure the dimensions of the piece of tile that you want to cut. Use a grease pencil to mark a straight line on the surface of the mirror.
Gently clamp a straightedge onto the top of the mirror tile. Clamp both sides so that the tile doesn't slip during the cutting.
Align your straightedge with the lines you marked.
Press onto the mirror tile and run the glass cutter along the straightedge. Apply even and firm pressure with the glass cutter.
Once you have etched the tile, remove the clamps. Gently bend the mirror along the etching until it snaps.
If that doesn't work, don't force it.
Gently tap the outer edge of the scored area with your glass cutter. The outer edge should simply pop or snap off.
As a last resort, run a sharp tool along the scoring to break it.
Remember to wear safety goggles for this particular procedure. Working with glass is extremely dangerous, so have on proper eye and hand protection at all times.
Installing Mirror Tiles Using Creative Ideas
Mirror tiles are very convenient and can be used in any room of the house. In addition to being stylish, they are very practical and match any motif or color scheme.
They can also be arranged into any configuration, which means they can fit a space of any size.
There's practically nothing you can't do with mirror tiles and no design you can't create. Flex your DIY skills and start playing around with mirror tile ideas to add light and brightness to your interior design.
Mirror Tile FAQ
How Do You Secure Mirror Tiles to a Wall?
Mirror tiles are incredibly easy to install. All you need is double-sided tape.
After placing the tape on the backside of the tile, the tile can be pressed right onto the wall, the furniture, the pot, or whatever else you want to tile. It's just that simple to install mirrored tile.
Do I Need to Grout Mirror Tiles?
Unlike other types of tiles, mirror tiles do not need grout. You don't have to worry about grout lines or move at a certain pace to keep the grout from drying out too quickly.
How Do You Cut a Mirror Tile Backsplash?
Cutting mirror tiles is possible but it's a slow procedure that requires you to work carefully. In short, the glass must first be scored and then gently snapped off.
Are Mirror Tiles Easy to Break in Half?
Mirror tiles are not easy to break in half. They must be scored first and sometimes, they are still stubborn and difficult to break just the same.
It is necessary to work slowly and precisely with glass tiles because glass is quite dangerous. It can shatter into very small shards that do a lot of damage to the soft tissues of your body, which is something you do not want.
Can a Tile Cutter Cut a Mirror?
You can use a tile cutter on mirror tiles but only if the tile cutter is equipped with a blade designed to cut glass. You cannot and should not use a standard tile saw to cut into mirror tile.
Can You Paint over Mirror Tiles?
If you decide you want to paint over your mirror tiles to change up the look of your interior spaces, no problem. Enamel paints are formulated specifically to stick to glass, so you can easily use this type of paint to cover mirror tiles if you choose.
What Do You Use to Install Mirror Tiles?
All you need to install mirror tiles to any surface is double-sided tape, a product that can be found in any hardware or home improvement store.
How Much Does It Cost to Install Mirror Tiles?
Home improvement projects are scary because they're going to cost money. And usually, when you're talking about a big project in the bathroom, kitchen, or another major room of the house, you're talking about spending a lot of money.
However, mirror tiles installation is one of the more affordable options you have if you want to effect a big change in your space without spending a lot. On average, mirror tiles cost about $10 per 10 square feet of space.
This is highly affordable and means that you can add mirror tiles to your home with very little expense, as compared to other DIY projects you could try.
Mirror Tile FAQ
10 Hacks For Customizing Furniture
Furniture Refinishing - Preparation
