How to Install Soundproof Glass
Hallway with several large windows
  • 2-20 hours
  • 0-3,000
Glass sheets
Screwdriver
Insulation foam or seal
Soundproof glass is used for a variety of essential or luxurious needs. Soundproof glass is ideal to make your own home cinema theater or just to enjoy the peace and quiet in your home by blocking unwanted external sound, such as, traffic noise, etc. There are different types of soundproof glass available on the market, but in order to make the best out of them you have to choose one that fulfills your needs. Another property of soundproof glass is that it also acts as an insulator, thus stopping drafts, resulting in cheaper electric bills.
In choosing your soundproof glass it is advisable to buy at least an 1/8 inch thick glass, allowing enough space between the two layers to effectively bar sound out of your room. Obviously, because installation is a crucial step, if you don’t have any type of experience in handy work you might want to contact someone who does, like a professional glass installer. However, if you want to try it yourself, here is how it’s done.
Normally vinyl is used instead of wood for the frame because wood tends to transmit sound. To add further protection, soundproof glass is laminated by a layer of transparent plastic, thus giving the glass protection against ultraviolet light and makes the glass shatter resistance for safety.
Step 1 - Fit the Window
Spray insulation around a window
A soundproof window can be quite heavy so it’s better if you ask a friend to help you. The first thing to do is to fit your glass sheet into the frame. Don’t rush this step because it’s essential that it’s perfect. Check that all of the corners are in their correct place to avoid any loosening at a later stage.
Step 2 - Install Insulation Foam
Now once the soundproof glass is in its frame, fill the gaps with the insulation foam. Double check your work to ensure no gaps have been forgotten. To ensure the best work possible, overflow the insulation foam and clean it with a moist cloth afterward (don’t let it dry because it will be much more difficult to remove). In this way you make sure all of the gaps have been properly filled with the insulation foam.
Step 3 - Install Screws in the Frame
Woman at on the phone with laptop open
Your next step is to replace any screws you have taken out of the frame to fit the soundproof window. Ensure all screws have been placed back in their original position.
Step 4 - Last Checks
Once everything is installed check that all is in place and also check that all of the locks and other bits and pieces work. Now leave the seal to dry.
Step 5 - Double Soundproof Window
For maximum quality you can install two soundproof windows. The method is the same but obviously the frame has to be able to support two soundproof glasses.
