How to Laminate a Table Top
a wood tabletop
  • 2-4 hours
  • 20-100
Self-adhesive laminate sheet
Sharp utility knife
Chisel
Protective goggles
Face mask
Heavy duty scissors
Large Rule
Sandpaper
Soft cloth
Tape measure
Sharp utility knife
Chisel
Protective goggles
Face mask
Heavy duty scissors
Large Rule
Sandpaper
Soft cloth
Tape measure
A laminate table top is hard wearing and practical for the kitchen. You can easily apply laminate to a table top, giving it a new lease of life at a fraction of the cost of replacing the table.
Step 1 - Choose Your Laminate
Laminate is available in sheets from most hardware stores. It is generally between 0.5 and 1.5 mm thick. You should also look out for the technical specifications on the manufacturer's guidelines that will show you how good the laminate's resistance to wear, scratching, staining, and fire is. If your laminate is not self-adhesive, you will also need wood glue.
Step 2 - Prepare Your Table
Prepare your table for laminating by sanding the top down with sandpaper. This will give the table a smooth surface ready for the laminate. You'll want to wear a face mask and safety glasses while sanding to avoid getting particles of wood stain or finish into your eyes or lungs. Once you have fully sanded the surface down, remove the dust with a soft cloth or a vacuum cleaner with a soft brush attachment.
If the table already has a laminated or veneered surface, you will need to remove this first with a chisel. Wedge the chisel underneath the veneer and ply the layer off a little at a time. Use protective goggles when you are doing this in case any splinters come off. You will be able to sand down any dried on glue that is left underneath.
Step 3 - Measuring Your Table
Before you cut the laminate, you need to measure the table with a tape measure. You should then add 1 inch to each side of the table measurements when measuring and cutting out the laminate.
Step 4 - Measure and Cut the Laminate
Measure the laminate to your table measurements and carefully cut it with a utility knife. Use a large rule to make sure you cut the sides in a straight line, cutting along the side of the rule with the knife. Take care not to scratch the new laminate.
Step 5 - Applying the Laminate
Remove the backing from the self-adhesive laminate and position the laminate so that each table edge has the extra inch of laminate hanging over it. If you are gluing your laminate, apply a thin layer of wood glue to the table before placing the laminate. Press the laminate firmly down onto the table top and push firmly over the laminate to secure it.
It is always a good idea to then cover the table with books or other heavy objects and leave it overnight so that the adhesive layer has a full chance to set. Once you are satisfied that the laminate is fully secure you should now carefully cut around the table using some heavy duty scissors to remove the excess laminate from each of the table sides.
Step 6 - Finishing the Table
The last stage is to sand the edges of the table lightly so that there is an even finish all the way round.
