How to Lengthen a Solid Wood Door
white wooden door on gray background
  • 2-5 hours
  • 50-200
Strong epoxy
Sandpaper
Wood door
Screwdriver
Wood
Wood putty
Putty knife
Wood stain
Table saw
Measuring tape
Pencil
Tack cloth
Strong epoxy
Sandpaper
Wood door
Screwdriver
Wood
Wood putty
Putty knife
Wood stain
Table saw
Measuring tape
Pencil
Tack cloth
If you have a solid wood door that is too short for your frame it can help run up your heating and cooling bills significantly. It is possible to lengthen the door, and in the following article DIY will show you how to do it yourself.
Determine the Filler Size
In order to lengthen the solid wood door, you need to determine the size you need. Make sure the door is closed and take out the measuring tape. Place it in the center of the door at the bottom. Measure the distance between the bottom of the door and the floor. This is the size of the gap but not the size of the extra piece you are going to need. For that, you need to subtract at least a 1/8th of an inch for clearance.
Cut the Filler
In order to get the door filler to match the door you need to cut it correctly and you also need to use the right kind of wood. If your door is made out of cedar, then use cedar to make the filler. The same applies if it is pine, birch, or some other kind of wood. Place the filler wood next to the door to determine the best orientation for the grain of the wood. once the correct orientation is determined transfer the measurement you took in Step 1 onto the filler. Place the filler wood on the table saw and secure it in place, and then cut it along the line against the grain.
wooden doors
Prepare the Wood
Use the screwdriver to remove the hinges on the solid wood door you plan to lengthen. Once the door is removed, gently sand the bottom. There's no need to get too detailed with this step—you want it to be slightly roughed up. Do the same thing to the end of the filler piece you plan to attach to the door. Use a tack cloth to remove any dust generated from sanding.
Lengthening the Solid Wood Door
It's important that the epoxy is waterproof and cures quickly. Line the filler piece up with the bottom of the door to ensure the smooth fit and the grain is accurate as possible. Apply a beaded line of the epoxy on both the bottom of the solid wood door and the filler piece. Allow the epoxy to become tacky and then press both ends together. Make sure the pieces are even and then hold them together for at least two minutes. Apply wood putty to where the wood connects to further seal it. Use the putty knife to spread it out and, once dry, sand it down.
Finishing
One of the trickiest parts of this project is matching the wood. The easiest way is to sand down the original door to the bare wood then stain both sections with the same stain. You can also apply stain lighter than the original and begin darkening it until the color matches.
