How to Maintain a Home Backup Generator
1 hours
Beginner
- 0-15
A home backup generator can be very useful during blackouts, which can occur in times of bad weather conditions and emergencies. Avoid the inconvenience of not having electricity during these times by practicing proper maintenance.
Types of Generators
Generators are equipment that converts a type of mechanical energy into electrical energy. It is like a car engine, but rather than thrusting the wheels to roll and go forward, a generator creates an electric current to provide power to home appliances. As car engines are powered by fuel to produce mechanical energy, so are generators.
The usual generators available are propane, diesel, and gas-powered generators. Propane and gas-powered are excellent and competent, although compared to diesel generators, they require more maintenance.
Diesel-powered generators are tougher and have greater fuel efficiency. Then again, they can have trouble starting during very cold weather conditions since diesel sleeps when it is cold. Propane may function better during the cold season, but it must have an effective starting method. Avoid pull-start engines, except if it is needed for exercise.
Maintenance
A home generator should be maintained properly for secure and efficient operations. Start by reading the owner’s manual for your specific generator as it will have information on how to maintain the unit.
Clean the generator often. A damp cloth can tidy up the surfaces and a soft brush can get rid of any caked-on substances.
The manufacturer usually suggests changing the oil of the generator often while it is in operation or as a standard maintenance procedure. If it is not in use, changing of oil is normally done once a year.
Check and service the spark plug system. The gap between services depends on the length of time the generator is in use or stored. If it is not in use, have it serviced once a year.
When checking and changing the oil, make sure the air cleaner system is checked and cleaned.
Run the generator once in a while to ensure that it is in good operating order.
