How to Make a Distressed Wood Frame
A wood frame.
  • 1-2 hours
  • 20
Ready made frame
Old wood (if you are making your own frame)
Saw
Wood glue
Woodworkers clamps
Varnish
Paint (to paint frame)
Wood stain (for stained frame)
Rags
Cotton swab
Ready made frame
Saw
Wood glue
Woodworkers clamps
Varnish
Rags
Cotton swab
Making a distressed wood frame is a fairly simple project. Distressed wood is popular in rustic decors as well as in masculine themes. You can use either a purchased frame or build your own frame for this project.
Step 1 - Get Your Frame Ready
Determine the size frame you will need. Frame sizes are by inside dimensions or glass size. If you are a novice at woodworking or don't have the tools mentioned above, purchasing a ready made frame would be the best choice for you. Find a color and size you like or even purchase an old frame from a thrift store. Remove the glass and keep it.
If you are making a frame you will want to measure the wood lengths for the inside dimensions, both width and length. Remember you will want the outside dimensions. Using the miter box, cut the ends to 90-degree angles. If you don't want to deal with a mitered corner, you can put together flat edges by cutting the wood to meet the inside dimensions you want. Then glue the pieces together at the corners. Clamp them with the woodworker clamps until snug. Wipe away all the glue that oozes out. Allow it to dry overnight.
Step 2 - Distress the Wood
When your frame is dry, you can start to distress it. You can use a screwdriver or any sharp object, such as an awl, or a large nail to scratch the surface of the wood to make it look old. Another technique is to hit it with a metal chain to make irregular marks in the wood. You can also hold a flame to the wood to give scorched or burned marks on it. When you are satisfied with the look its time to add age to the marks.
Step 3 - Add Aging
Dab a little black or brown paint on a cotton swab or rag, and rub the paint into the marks you've made to fill in the crevices. Gently wipe away the excess paint on the smooth part of the wood. This will help you tell if you have enough marks on the wood to please you. If not, just add more and add more paint.
When the paint is dry, you can add a wood tone stain over the entire frame, let it sit for a few minutes and wipe away the excess. If you want a darker frame, you can put on another coat. When the stain has dried, varnish the entire frame.
Painted Frames
If you want a painted frame that is distressed, reverse the above instructions. Paint the frame the color you want. When the paint has dried, add black paint into the marks and wipe away the excess. Then apply a coat of varnish to seal the frame.
Other Techniques
Different looks can be achieved by using different colors of paint in the marks you've made instead of black. You can also use more than one color on the base of the frame. Paint on one color, let it dry, then apply another coat in a different color. When it has dried, sand through part of the topcoat to give it an aged look.
