How to Make Custom Storm Doors Blueprints
Lead Image for How to Make Custom Storm Doors Blueprints
  • 2 hours
  • 25
24-inch by 36-inch newsprint sheets
Scale ruler
T-square
Drafting table
Large memory computer 500 Gb
Blue print drafting software
Portable memory card or USB stick
Scale ruler
T-square
Drafting table
In order to create the custom storm doors you want for your home, consider drawing up a custom storm door blueprint. Sketch the blueprint onto newsprint and take it to a blueprint production company, or you can use blueprint software to draw the blueprint and just get it printed.
Step 1 - Decide on the Size of Your Custom Storm Door
Standard sizes of storm doors are 30, 32, 34, and 36 inches in width, and 80-inches or 96-inches high. These sizes will serve as a base for your door's outline. Draw the outline on your newsprint or input it into your blueprint drafting software.
Step 2 - Choose the Materials for Your Storm Door
Your storm door can be made of solid wood, vinyl over a wood or steel core, fiberglass, aluminum, sheet steel, or a variety of other metals. Other metals such as copper can also be applied as cladding to your storm door. You can also add decorative molding to your storm door, in the same metal as the base or in other metals.
Step 3 - Add the Windows
Add to your drawing the window configuration you prefer. These will include the type of window in your door. Choose a high-view window, just at the top, or a mid-view window with glass in the middle 2/3 of the door, and movable panels that allow a screen opening to let in the fresh air. A full-view storm door will have a solid glass panel from top to bottom. You can choose to divide the door width into three panels, two of which will have glass sliding panels that cover screens. Select the glass type you prefer as well, from clear glass, etched glass, or even a stained-glass artwork.
Step 4 - Add Handle and Lock
Choose the handle type you prefer, and add it to your blueprint drawing. It can be a lever handle or a vertical loop handle with a pushbutton latch release. You can also add a keyed deadbolt lock that is much more secure than the simple latch lock usually supplied with storm doors.
Step 5 - Add Chain Catch and Door Open Brace
At the top of your screen door, add a chain catch to stop the door from blowing back onto its hinges in a strong breeze. You can also include a door-open brace, generally a cylinder and rod with a large nut attached. When you move the nut away from the cylinder along the rod, the door will open to the rod length specified, and stay there till you slide the nut back to the cylinder.
Step 6 - Add Decorative Molding
Add a decorative molding panel to your storm door below or around the windows, in any design you like. Draw your molding design onto the blueprint so the door manufacturer can create it. If you are building a wooden storm door, you can use carving and embossing tools to add the decorative molding yourself.
