How to Make PVC Solvent Cement
If you are looking for a suitable PVC solvent cement, then you may be fed up with searching, and decide instead to make your own. PVC cement is a vital ingredient in many types of home repairs, from basic plumbing to large-scale kitchen or bathroom installations. PVC pipes require a particular kind of glue, known as PVC solvent or cement. Making this product can be very difficult, as it is a chemical compound, and most people would be better off finding some PVC solvent cement from the Internet. If you are determined to make your own, then you should consider choosing to make a fiber cement mix which avoids the dangers of using Polyvinyl Chloride.
Step 1 - Mixing the Materials
Take a suitable mixing bowl, large enough to hold the quantities and stir them around without them falling out. Gather together the items you will need, including Portland cement, sand, fibers from wood or plant products, and some water. Mix together the cement and the sand until they are completely blended. The cement and sand should be mixed half and half until they are blended. Take the cement and sand mix over to the water, and add a little at a time until you have a loose paste. Once the paste is made, you should begin to add the wood fiber.
Step 2 - Adding the Wood Fibers
The wood fiber should be added slowly to the cement paste. These fibers are suitable binding agents which keep the product from falling apart once the water dries out. Keep stirring this until you have a mix of 90 percent paste, and 10 percent wood fiber. You can find a number of suitable fiber parts, such as wood chips, or even coconut fiber. The plant material will help to keep the cement parts together, so that you can use it to bind other things such as pipes together into one.
Step 3 - Add the Wax
Once you have added the fiber to the cement, leave it to stand for 24 hours. After returning, stir it to make sure that there is no water left at the bottom of the mix. Take some wax or resin which has been shredded, and add this to the mix, stirring slowly with the spoons. This takes the place of the PVC mix in the solvent cement.
Step 4 - Applying the Cement
When you are ready, you can take a little of the cement mix, and apply it to the surface of the pipe. Keep holding the pipe together until the cement dries completely, and then add a layer of caulk over the top of the pipe. This will keep the cement from getting too wet to stick, and also preserve it in place. If you have any cement left over once you are finished, you can store this in an air-tight plastic pot until you need it again.
